1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Python client application survey
To: [email protected]
Cc: [email protected]
Date: Fri, 2 Oct 2009 13:03:39 -0500
On Friday 02 October 2009 12:16:19 [email protected] wrote:
> > Why not make that flag into an optional data type name
> > instead; if not supplied you would default to whatever
> > you were doing before, but as well as controlling whether
> > strings get sent as a DBF_STRING or DBF_CHAR, this could
> > also allow the user to tell your API "please convert my data
> > to this type before sending it."
> Very tempted to do this for caget, but for caput I don't currently offer
> the caller control over the conversion -- instead, I convert the data to
> whatever format fits, so for scalars I only do caputs in LONG, DOUBLE or
> STRING (waveforms get the lot, except for ENUM).  Hmmm.... very tempting to
> add a datatype specifier, actually, not sure if it'd be useful though?
My original example actually said something like "please send this large array
of numbers as a DBF_SHORT array" — I think a data-type specifier *would* be
useful in some circumstances, especially for the small IOC people.
> Huh: did you know that if you do
> 	caget('STRING-PV-ENDING-IN.$', datatype=str)
> you get an array of strings, each string containing the decimal
> representation of each character in the PV?  Very entertaining!
Yup, makes perfect sense when you understand how it all works; dbNameToAddr()
which does the IOC's PV name parsing saw the field modifier and told the CA
server that the PV's native type was an array of characters, but you asked to
be given an array of strings so CA did the standard int => string conversion
on each element before sending you the result.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: EPICS Python client application survey michael.abbott
Prev: Channel access and ca_element_count michael.abbott
Next: Re: state notation code flags Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS Python client application survey michael.abbott
Next: Channel access and ca_element_count michael.abbott
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
