1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: state notation code flags
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Sat, 3 Oct 2009 17:17:25 -0500
I forgot to mention, that I tried your example (with busy loops removed) on R3.14.11. My test IOC has been sitting there for half an hour now without printing the message.
On Oct 3, 2009, at 5:13 PM, Eric Norum wrote:
There seems to be a fundamental misunderstanding in your use of the sequencer. The default action, if no state transition 'when' statement is true, is to stay in the same state waiting for a statement to come true. Your examples have lots of statements like:
	state clear {
		when(efTestAndClear(test_putEvent)) {
			efClear(test_putEvent);
		} state wait
		when () {
		} state clear
The above code is bad. It sets the sequencer into a busy loop consuming all available CPU.
I think what you want is the following:
	state clear {
		} state wait
This code blocks the sequencer until something 'interesting' happens at which point it rescans the 'when' statements and checks to see if any of them are now true.
I suspect that your 'flag' problem is occurring because the busy loops you've constructed are preventing other threads from getting the CPU they need.
On Oct 3, 2009, at 4:46 PM, Patrick Thomas wrote:
Hi Mark,
Why does this still sometimes print out the flag?
program sncTest
float test_put;
assign test_put to "H3:TEST_PUT";
monitor test_put;
evflag test_putEvent;
sync test_put test_putEvent;
ss ss1 {
	state init {
		when () {
			test_put = 40;
			pvPut(test_put, SYNC);
		} state clear
	state clear {
		} state wait
		when () {
		} state clear
	state wait {
		when (efTest(test_putEvent)) {
			printf("flag set\n");
		} state loop
		when () {
		} state wait
	state loop {
		when () {
		} state loop
Mark Rivers wrote:
Hi Patrick,
What is it you are trying to do? You are doing both pvPuts and looking for external changes to the same PV? If so, then one solution is to ignore events which correspond to the value that your SNL program set with pvPut, and only act on events with values that must have been done by some external agent. Here is an example from one of my programs:
int     abort;       assign abort        to "{P}{R}Abort.VAL";
monitor abort;
evflag abortMon;        sync abort      abortMon;
ss xpsTrajectoryAbort {
  state monitorAbort {
      when ((efTestAndClear(abortMon)) && (abort==1) &&
            (execState==EXECUTE_STATE_EXECUTING)) {
          abort=0;
          pvPut(abort);
      } state monitorAbort
In this case abort can be set to 1 by the user from outside the SNL program. If that happens then the SNL program takes some appropriate action, and does a pvPut of abort back to 0. That would cause another event to be received, but I ignore that event in the when clause()
This will always clear event flags on the abort PV, but will only do the logic inside the when if abort is 1 and execState is EXECUTE_STATE_EXECUTING.
Sent: Sat 10/3/2009 12:37 AM
To: Mark Rivers
Cc: [email protected]; [email protected]
I see, thank you. So is there a way around this, that is to make sure the monitors are received and the flag is set before the call to efClear is made, or some way to make a particular pvPut not have channel access
send out monitors for that record?
Mark Rivers wrote:
I think I have figured it out, the following code shows it the most clearly. Adding SYNC to the pvPut command does not seem to ensure that
it will finish before the next command is processed:
The pvPut command did "finish" before the efClear command was executed. That means that it wrote its value to the record, and processed that record and any records that process as a result of processing that record. That record told channel access to send out monitors on that PV to all clients, including your SNL program. It does NOT wait for those monitors to be received; it simply requests channel access to send them, which is then done asynchronously. So the event flag in your SNL program will be set some time after you do the pvPut. What you are observing is the expected and documented behavior of EPICS.
Sent: Fri 10/2/2009 7:03 PM
To: [email protected]
Cc: Mark Rivers; [email protected]
program sncTest
float request_maximum_velocity;
assign request_maximum_velocity to "H3:TEST";
monitor request_maximum_velocity;
evflag request_maximum_velocityEvent;
sync request_maximum_velocity request_maximum_velocityEvent;
ss ss1 {
      state init {
              when () {
                      efClear(request_maximum_velocityEvent);
                      request_maximum_velocity = 40;
                      pvPut(request_maximum_velocity, SYNC);
              } state wait
      state wait {
              when () {
                      if (efTest(request_maximum_velocityEvent)) {
              } state wait
Pete R. Jemian wrote:
sounds a bit off ... show the code
I think I have it narrowed down. It appears that when I set variable1 equal to variable2 and variable2 has a flag synced to it (variable1 does not), and then do a pvPut on variable1, sometimes the flag is set on variable2 and sometimes it isn't. Am I correct? Why does this
occur?
Thank you,
Patrick
Mark Rivers wrote:
Patrick,
Event flags can be explicitly set, which is typically used to allow communication between state sets. Or event flags can be synced to a
PV,
and will be set whenever a monitor is received for that PV, as in the
example I sent you.
You can use the efTest() function outside of a when statement, just
like
any other function.
-----Original Message-----
From: Patrick Thomas [mailto:[email protected]] Sent:
Thursday, October 01, 2009 5:20 PM
To: Mark Rivers
Hi Mark,
Are the flags on a monitored variable set whenever the monitored
variable is used in the code, including a pvPut, pvGet, assignment, calculation, or print statement? Is there a way to test if the flag
is set besides an efTest in a when statement?
Thank you,
Patrick
Mark Rivers wrote:
Hio Patrick,
Here are some code snippets from one of my SNL programs. It has a
variable nelements assigned to a PV, and a monitor on that PV. It has an event flag, nelementsMon that is synced to nelements. Whenever nelements changes the event flag will be set. In the init state I
clear
the event flag, just to be sure it is clear when the SNL code starts running (after all PVs connect). I then use efTestAndClear in a when statement to take actions when that event flag is set, and to clear it.
This works fine for me.
int nelements; assign nelements to "{P} {R}Nelements.VAL";
monitor nelements;
evflag nelementsMon;    sync nelements  nelementsMon;
  /* Initialize things when first starting */
  state init {
      when() {
          /* Clear all event flags */
          efClear(nelementsMon);
      } state monitor_inputs
  state monitor_inputs {
      when(efTestAndClear(nelementsMon) && (nelements>=1)) {
/* If nelements changes, then change endPulses to this
value,
* since this is what the user normally wants. endPulses
can be
           * changed again after changing nelements if this is
desired. */
          if (moveMode == MOVE_MODE_RELATIVE)
              endPulses = nelements;
          else
              endPulses = nelements-1;
          pvPut(endPulses);
From: [email protected] on behalf of Patrick Thomas
Sent: Wed 9/30/2009 10:35 PM
Subject: state notation code flags
I was wondering if there is a way to track at what point in the state notation code evflags are getting set and cleared, or if someone could clarify under what conditions they get set. I'm having trouble with
them
getting set somewhere and not being cleared, but I'm not sure where.
Thank you,
Patrick
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
(630) 252-4793
Re: state notation code flags Patrick Thomas
RE: state notation code flags Mark Rivers
Re: state notation code flags Pete R. Jemian
Re: state notation code flags Eric Norum
Prev: Re: state notation code flags Eric Norum
Next: RE: state notation code flags Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: state notation code flags Patrick Thomas
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
