1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: EPICS build for MVME3100
To: "William F. Steele" <[email protected]>
Cc: [email protected]
Date: Thu, 15 Oct 2009 12:00:31 -0500
Hello William,
According to this WRS web page;
http://www.windriver.com/products/bsp_web/bsp_architecture.html?architecture=PowerPC
it does not look like the MVME3100 is supported with Tornado 2.2.1.
Ron
William F. Steele wrote:
I don't understand how to build EPICS for MVME3100. I have no problem with mcp750, mvme2100, 68040, or 68060. I am trying to build EPICS 3.14.11 and am using vxWorks 5.5.1 with Tornado 2.2.1. If I put vxWorks-mpc8540 in my list of CROSS_COMPILER_TARGET_ARCHS, I get compile errors which I traced to ARCH_DEP_CPPFLAGS which is set to -DCPU=PPC32 which the compiler does not recognize. If I change that to ARCH_DEP_CPPFLAGS = -DCPU=PPC85XX, then I no longer get compile errors, but EPICS will not load due to a lot of undefined symbols. I talked to WRS about this problem and was advised that I was using the wrong compiler. When I use Tornado to build vxWorks, Tornado uses /home/als2/devel/vxWorks/tornado2.2.1-ppc/host/gnu/3.3/sun4-solaris2/bin/ccppc, but when building EPICS, the EPICS build system uses /home/als2/devel/vxWorks/tornado2.2.1-ppc/host/sun4-solaris2/bin/ccppc, so, apparently, the EPICS build system does not automatically setup to use the correct tools when specifying the target
vxWorks-mpc8540. What needs to be done to make this work right? Thanks.
RE: EPICS build for MVME3100 Erik Johansson
RE: EPICS build for MVME3100 Lawrence T. Hoff
EPICS build for MVME3100 William F. Steele
Prev: Canberra G64 Radiation Monitor Support? keith.baker
Next: RE: EPICS build for MVME3100 Erik Johansson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: EPICS build for MVME3100 Dirk Zimoch
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
