Hi Peter,
Unfortunately, I had no time to test StreamDevice with any EPICS base version
newer than 3.14.8.2. Once I find the time -- maybe in 2017 :-) -- I check with
newer versions of base and asyn and also on 64 bit architectures. Then I can
build a new release.
On the other hand, one can probably live without StreamDevice support for
sCalcout records...
Sorry for the inconvenience,
Dirk
Dr. Peter Zumbruch wrote:
Thank you,
doing so I got further but still failed at other places
But after changing
in addition
1) in the streamApp/Makefile
streamApp_DBD += calc.dbd
into
streamApp_DBD += calcSupport.dbd
and
2) added to the <TOP>/configure/RELEASE the line
SSCAN=<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/sscan/2-6-4
I finally succeeded.
So I did the same what has been done for synApps.
Did I miss some part of documentation in relationship to EPICS 3.14.10
in StreamDevice docs about this
and if not could this be added?
Thank you and best regards
Peter
Tim Mooney wrote:
Peter,
EPICS 3.14.10 doesn't build libiocsh, as previous versions id.
You need to remove iocsh from the line
LIB_LIBS += stream dbIoc registryIoc iocsh
in srcSynApps/Makefile.
You'll still get iocsh, because base now has it in libCom.
Tim
Hi everybody,
when compiling streamDevice 2.4 from psi web page with CALC set in the
RELEASE file
I get the following output
base: 3.14.10, Debian 4.0
make[2]: Entering directory
`<EPICS_TOP>/modules/soft/StreamDevice/StreamDevice-2-4/srcSynApps/O.linux-x86'
Installing created dbd file ../../../dbd/streamSynApps.dbd
/usr/bin/gcc-3.4 -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500
-D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3
-Wall -m32 -g -fPIC
-I. -I../O.Common -I. -I.. -I../../../include/os/Linux
-I../../../include
-I<EPICS_TOP>/modules/soft/seq/sncseq-2.0.12/include
-I<EPICS_TOP>/base-3.14.10/include/os/Linux
-I<EPICS_TOP>/modules/soft/asyn/asyn-4.10/include
-I<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/calc/2-7/include
../devscalcoutStream.c
/usr/bin/ar -rc libstreamSynApps.a devscalcoutStream.o
/usr/bin/ranlib libstreamSynApps.a
make[2]: *** No rule to make target
`../../../lib/linux-x86/libiocsh.a', needed by
`libstreamSynApps.so'. Stop.
make[2]: Leaving directory
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory
`<EPICS_TOP>/modules/soft/StreamDevice/StreamDevice-2-4/srcSynApps'
make: *** [srcSynApps.install] Error 2
without CALC set, everything compiles the right way.
and here the corresponding RELEASE
#RELEASE Location of external products
#If using the sequencer, point SNCSEQ at its top directory:
SNCSEQ=<EPICS_TOP>/modules/soft/seq/sncseq-2.0.12
# EPICS_BASE usually appears last so other apps can override stuff:
EPICS_BASE=<EPICS_TOP>/base
ASYN=<EPICS_TOP>/modules/soft/asyn/asyn-4.10
CALC=<EPICS_TOP>/modules/synApps/synApps_5_4_1/support/calc/2-7
PCRE_INCLUDE=/usr/include/pcre
PCRE_LIB=/usr/lib
Any help would be appreciated,
Peter
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- RE: compiling streamDevice with CALC set fails Mark Rivers
- compiling streamDevice with CALC set fails Dr. Peter Zumbruch
- Re: compiling streamDevice with CALC set fails Tim Mooney
- Re: compiling streamDevice with CALC set fails Dr. Peter Zumbruch
macLib/msi changes with 3.14.10 Till Straumann
Re: devLibOSD.c for Linux Dirk Zimoch
<2009>
2025
devLib changes Davidsaver, Michael
<2009>
2025
