I don't think this is true. The Canadian Light Source and the
Australian Synchrotron are using Linux with VME via the SIS PCI to VME
bridge. I believe there is a version of devLib that supports this.
They are using a recent version of the IPAC module for VME Industry Pack
modules, and I believe IPAC uses devLib.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Dirk Zimoch
Sent: Friday, October 23, 2009 9:20 AM
To: Mi Qingru
Cc: epics tech-talk
Subject: Re: devLibOSD.c for Linux
Mi Qingru wrote:
> hi,
> Base-3.14.8.2 and base-3.14.11 only support devLib.c on vxWorks and
> RTEMS. How to use the routines in devLib.c for Linux?
> Mi Qingru
> 2009-10-22
You simply have to write them :-)
Most of the routines refer to VME bus. They probably don't make much
sense on an
ordinary Linux PC. But there might actually be some Linux based VME
systems.
However it seems that nobody has used such systems so far. It's like
everything
in EPICS: The first one who needs a feature has to implement it.
Good luck and tell us when you're done :-)
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Re: devLibOSD.c for Linux Andrew Johnson
- devLibOSD.c for Linux Mi Qingru
- Re: devLibOSD.c for Linux Dirk Zimoch
RE: compiling streamDevice with CALC set fails Mark Rivers
<2009>
<2009>
