Here are the details of my testing with a summary preceding.
Thanks for taking a look, Geoff
Summary:
EPICS R3.14.8.2 on VxWorks 5.5 - no significant patches.
IOC A IOC B
so ------> mbbo
Action: Boot both IOCs at the same time.
Action: Reboot IOC B.
IOC A - CA disconnect message
camonitor - CA disconnect message
mbbo 2009-11-23 14:31:01.368860 ***
disconnected
mbbo <undefined> DEFAULT UDF INVALID
Action: Reboot IOC A - no change.
Action: Process "so" record by writing to "so.PROC" from CA client on
host.
IOC B - CAS-client: Process so
IOC A - CAS-client: Process mbbo
camonitor -
mbbo 2009-11-23 14:34:19.586319 OFF
IOC B - CAS-client: Process mbbo
camonitor -
mbbo 2009-11-23 14:38:58.308664 OFF
Details:
IOC A IOC B
so ------> mbbo
IOC A (mv2304, d0olctl145)
record(stringout, "so")
field(DTYP, "Soft Channel")
field(OUT, "mbbo")
field(VAL, "OFF")
field(SCAN, "Passive")
field(OMSL, "supervisory")
field(TPRO, "1")
-> dblsr "so", 2
globalLock 0x2e55590
lockSetModifyLock 0x2e55520
Lock Set 1 1 members epicsMutexId 0x2e729c0 Not Locked
so
value = 0 = 0x0
IOC B (mv2300, d0olctl34)
record(mbbo, "mbbo")
field(OUT, "0")
field(SHFT, "0")
field(NOBT, "8")
field(ZRST, "DEFAULT")
field(ZRVL, "0")
field(ONST, "ON")
field(ONVL, "1")
field(TWST, "OFF")
field(TWVL, "2")
field(TPRO, "1")
-> dblsr "mbbo", 2
globalLock 0xc32d78
lockSetModifyLock 0xc32d28
Lock Set 1 1 members epicsMutexId 0xc32c80 Not Locked
mbbo
value = 0 = 0x0
Boot both IOCs.
Start camonitor on a Linux host -
> camonitor mbbo
Reboot IOC B
camonitor output -
Unexpected problem with CA circuit to server "d0olctl34.fnal.gov:5064"
was "Connection reset by peer" - disconnecting
CA.Client.Exception...............................................
Warning: "Virtual circuit disconnect"
Context: "d0olctl34.fnal.gov:5064"
Source File: ../cac.cpp line 1142
Current Time: Mon Nov 23 2009 14:31:01.368765000
Printed on IOC A -
was "S_errno_ECONNRESET" - disconnecting
DB CA Link Exception: "Virtual circuit disconnect", context
camonitor output when IOC B finishes reboot -
disconnected
Reboot IOC A
nothing changes
Write to so.PROC. (so sends "OFF" to mbbo)
camonitor -
Reboot IOC B
camonitor output -
Current Time: Mon Nov 23 2009 14:38:33.260917000
mbbo 2009-11-23 14:38:33.261021 ***
disconnected
Printed on IOC A -
Summary:
EPICS R3.14.8.2 - no significant patches.
IOC A IOC B
so ------> mbbo
Boot both IOCs.
Action: Reboot IOC B - no change.
disconnected
host.
camonitor -
camonitor -
Begin forwarded message:
Date: November 13, 2009 2:24:28 PM CST
To: [email protected]
Cc: Geoff Savage <[email protected]>
Subject: Re: CA link behavior
Hi Geoff,
On Friday 13 November 2009 13:38:36 Geoff Savage wrote:
I have a passive stringout record in IOC A whose OUTLINK references
an
mbbo record in IOC B. When I reboot IOC B the value in the stringout
record is written to the mbbo record even though the stringout record
has not been processed.
A bit more background. The stringout record will be processed by a
calc record when a temperature becomes too high. The mbbo record
controls the power to a front end board. So the value being written
is to power off the front end board whenever the IOC B is rebooted.
This doesn't sound like it should be happening, unless there's
something else
going on. Have you tried setting TPRO on the mbbo record? The
output from
dblsr "<mbboRecordName>", 2
might provide some more clues as well.
Can you post the two complete record definitions extracted from
their .db
files, and the output from dbpr on both records with an interest
level 3 or
higher. Also the Base version number that you're running (and
whether it
contains any significant modifications to the official release), and
the
target architectures of the two IOCs for completeness sake.
- Andrew
The best FOSS code is written to be read by other humans -- Harald
Welte
- Re: Fwd: CA link behavior Andrew Johnson
- Re: CA link behavior Andrew Johnson
RE: error building mca6-11 Mark Rivers
CA problem w EPICS 3.14.11 & VxWorks 6.7 GOURNAY Jean-Francois
<2009>
2025
Re: CA link behavior Emmanuel Mayssat
<2009>
2025
