hi, Mark:
but your prebuild version does not crash if can't connect to camera......what's difference between? I also tried static build.
======= At 2009-11-28, 21:20:26 you wrote: =======
>Hi,
>The problem is here:
>prosilicaConfig("PS1", 51031, 50, 200000000)
>[New Thread 0xb7fc5b90 (LWP 22428)]
>[New Thread 0xb7f84b90 (LWP 22429)]
>[New Thread 0xb7f43b90 (LWP 22430)]
>[New Thread 0xb7ee1b90 (LWP 22432)]
>[New Thread 0xb7f02b90 (LWP 22431)]
>[New Thread 0xb7ea0b90 (LWP 22433)]
>[New Thread 0xb749fb90 (LWP 22434)]
>2009/11/29 15:42:02.191 prosilica:connectCamera: Cannot find camera 51031
>prosilica:prosilica: cannot connect to camera 51031, manually connect when available.
>It cannot find the camera. Is that the correct UniqueId? Is the camera in use by some other program? Is it on a different subnet?
>Mark
>________________________________
>From: Silver [mailto:[email protected]]
>Sent: Sat 11/28/2009 1:35 AM
>To: Mark Rivers
>Subject: Re: RE: error building mca6-11
>hi, Mark:
> when I compiled the areaDector and run it, it will crashed. while when I run the prebuild file, it's ok. following is the gdb information, can you give some suggestions?
>/usr/local/epics/r3.14.10/support/areaDetector/1-5/iocBoot/iocProsilica>gdb ../../bin/linux-x86/prosilicaApp
>GNU gdb Fedora (6.8-32.fc10)
>Copyright (C) 2008 Free Software Foundation, Inc.
>License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
>This is free software: you are free to change and redistribute it.
>There is NO WARRANTY, to the extent permitted by law. Type "show copying"
>and "show warranty" for details.
>This GDB was configured as "i386-redhat-linux-gnu"...
>(gdb) run st.cmd.linux
>Starting program: /usr/local/epics/r3.14.10/support/areaDetector/1-5/bin/linux-x86/prosilicaApp st.cmd.linux
>[Thread debugging using libthread_db enabled]
>< envPaths
>epicsEnvSet("ARCH","linux-x86")
>epicsEnvSet("IOC","iocProsilica")
>epicsEnvSet("TOP","/usr/local/epics/r3.14.10/support/areaDetector/1-5")
>epicsEnvSet("ASYN","/usr/local/epics/r3.14.10/support/asyn/4-12")
>epicsEnvSet("CALC","/usr/local/epics/r3.14.10/support/calc/2-7")
>epicsEnvSet("BUSY","/usr/local/epics/r3.14.10/support/busy/1-2")
>epicsEnvSet("SSCAN","/usr/local/epics/r3.14.10/support/sscan/2-6-4")
>epicsEnvSet("MCA","/usr/local/epics/r3.14.10/support/mca/6-11")
>epicsEnvSet("AUTOSAVE","/usr/local/epics/r3.14.10/support/autosave/4-5")
>epicsEnvSet("AREA_DETECTOR","/usr/local/epics/r3.14.10/support/areaDetector/1-5")
>epicsEnvSet("EPICS_BASE","/usr/local/epics/r3.14.10/base")
>[New Thread 0xb7fe78e0 (LWP 22424)]
>[New Thread 0xb7fe6b90 (LWP 22427)]
>< st.cmd
>errlogInit(20000)
>dbLoadDatabase("/usr/local/epics/r3.14.10/support/areaDetector/1-5/dbd/prosilicaApp.dbd")
>prosilicaApp_registerRecordDeviceDriver(pdbbase)
># The second parameter to the prosilicaConfig command is the uniqueId of the camera.
># The simplest way to determine the uniqueId of a camera is to run the Prosilica GigEViewer application,
># select the camera, and press the "i" icon on the bottom of the main window to show the camera information for this camera.
># The Unique ID will be displayed on the first line in the information window.
>asynSetTraceIOMask("PS1",0,2)
>#asynSetTraceMask("PS1",0,255)
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/ADBase.template", "P=13PS1:,R=cam1:,PORT=PS1,ADDR=0,TIMEOUT=1")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDFile.template", "P=13PS1:,R=cam1:,PORT=PS1,ADDR=0,TIMEOUT=1")
># Note that prosilica.template must be loaded after NDFile.template to replace the file format correctly
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/prosilica.template","P=13PS1:,R=cam1:,PORT=PS1,ADDR=0,TIMEOUT=1")
>#prosilicaConfig("PS2", 50022, 10, 50000000)
>#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/ADBase.template", "P=13PS1:,R=cam2:,PORT=PS2,ADDR=0,TIMEOUT=1")
>#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/prosilica.template","P=13PS1:,R=cam2:,PORT=PS2,ADDR=0,TIMEOUT=1")
># Create a standard arrays plugin, set it to get data from first Prosilica driver.
>NDStdArraysConfigure("PS1Image", 5, 0, "PS1", 0, -1)
>[New Thread 0xb6a9eb90 (LWP 22435)]
>[New Thread 0xb6a5db90 (LWP 22436)]
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDPluginBase.template","P=13PS1:,R=image1:,PORT=PS1Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
># Use this line if you only want to use the Prosilica in 8-bit mode. It uses an 8-bit waveform record
># NELEMENTS is set large enough for a 1360x1024x3 image size, which is the number of pixels in RGB images from the GC1380CH color camera.
># Must be at least as big as the maximum size of your camera images
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDStdArrays.template", "P=13PS1:,R=image1:,PORT=PS1Image,ADDR=0,TIMEOUT=1,TYPE=Int8,FTVL=UCHAR,NELEMENTS=4177920")
># Use this line if you want to use the Prosilica in 8,12 or 16-bit modes.
># It uses an 16-bit waveform record, so it uses twice the memory and bandwidth required for only 8-bit data.
>#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDStdArrays.template", "P=13PS1:,R=image1:,PORT=PS1Image,ADDR=0,TIMEOUT=1,TYPE=Int16,FTVL=SHORT,NELEMENTS=4177920")
># Load the database to use with Stephen Mudie's IDL code
>#dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/EPICS_AD_Viewer.template", "P=13PS1:, R=image1:")
># Create a netCDF file saving plugin
>NDFileNetCDFConfigure("PS1FileNetCDF", 5, 0, "PS1", 0)
>[New Thread 0xb6a1cb90 (LWP 22437)]
>[New Thread 0xb69dbb90 (LWP 22438)]
>[New Thread 0xb699ab90 (LWP 22439)]
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDPluginBase.template","P=13PS1:,R=netCDF1:,PORT=PS1FileNetCDF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDFile.template", "P=13PS1:,R=netCDF1:,PORT=PS1FileNetCDF,ADDR=0,TIMEOUT=1")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDFileNetCDF.template","P=13PS1:,R=netCDF1:,PORT=PS1FileNetCDF,ADDR=0,TIMEOUT=1")
># Create a TIFF file saving plugin
>NDFileTIFFConfigure("PS1FileTIFF", 5, 0, "PS1", 0)
>[New Thread 0xb6959b90 (LWP 22440)]
>[New Thread 0xb67ffb90 (LWP 22441)]
>[New Thread 0xb67beb90 (LWP 22442)]
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDPluginBase.template","P=13PS1:,R=TIFF1:,PORT=PS1FileTIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDFile.template", "P=13PS1:,R=TIFF1:,PORT=PS1FileTIFF,ADDR=0,TIMEOUT=1")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDFileTIFF.template", "P=13PS1:,R=TIFF1:,PORT=PS1FileTIFF,ADDR=0,TIMEOUT=1")
># Create a JPEG file saving plugin
>NDFileJPEGConfigure("PS1FileJPEG", 5, 0, "PS1", 0)
>[New Thread 0xb677db90 (LWP 22443)]
>[New Thread 0xb673cb90 (LWP 22444)]
>[New Thread 0xb66fbb90 (LWP 22445)]
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDPluginBase.template","P=13PS1:,R=JPEG1:,PORT=PS1FileJPEG,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDFile.template", "P=13PS1:,R=JPEG1:,PORT=PS1FileJPEG,ADDR=0,TIMEOUT=1")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDFileJPEG.template", "P=13PS1:,R=JPEG1:,PORT=PS1FileJPEG,ADDR=0,TIMEOUT=1")
># Create an ROI plugin
>NDROIConfigure("PS1ROI", 5, 0, "PS1", 0, 10, 20, -1)
>[New Thread 0xb66bab90 (LWP 22446)]
>[New Thread 0xb6679b90 (LWP 22447)]
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDPluginBase.template","P=13PS1:,R=ROI1:, PORT=PS1ROI,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDROI.template", "P=13PS1:,R=ROI1:, PORT=PS1ROI,ADDR=0,TIMEOUT=1")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDROIN.template", "P=13PS1:,R=ROI1:0:,PORT=PS1ROI,ADDR=0,TIMEOUT=1,HIST_SIZE=256")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDROIN.template", "P=13PS1:,R=ROI1:1:,PORT=PS1ROI,ADDR=1,TIMEOUT=1,HIST_SIZE=256")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDROIN.template", "P=13PS1:,R=ROI1:2:,PORT=PS1ROI,ADDR=2,TIMEOUT=1,HIST_SIZE=256")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDROIN.template", "P=13PS1:,R=ROI1:3:,PORT=PS1ROI,ADDR=3,TIMEOUT=1,HIST_SIZE=256")
># Create 2 color conversion plugins
>NDColorConvertConfigure("PS1CC1", 5, 0, "PS1", 0, 20, -1)
>[New Thread 0xb6638b90 (LWP 22448)]
>[New Thread 0xb65f7b90 (LWP 22449)]
>NDPluginColorConvert:NDPluginColorConvert: failed to set integer param for color mode
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDPluginBase.template", "P=13PS1:,R=CC1:, PORT=PS1CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDColorConvert.template", "P=13PS1:,R=CC1:, PORT=PS1CC1,ADDR=0,TIMEOUT=1")
>NDColorConvertConfigure("PS1CC2", 5, 0, "PS1", 0, 20, -1)
>[New Thread 0xb65b6b90 (LWP 22450)]
>[New Thread 0xb6575b90 (LWP 22451)]
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDPluginBase.template", "P=13PS1:,R=CC2:, PORT=PS1CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1CC1,NDARRAY_ADDR=0")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db/NDColorConvert.template", "P=13PS1:,R=CC2:, PORT=PS1CC2,ADDR=0,TIMEOUT=1")
>set_requestfile_path("./")
>set_savefile_path("./autosave")
>set_requestfile_path("/usr/local/epics/r3.14.10/support/areaDetector/1-5/ADApp/Db")
>set_pass0_restoreFile("auto_settings.sav")
>set_pass1_restoreFile("auto_settings.sav")
>save_restoreSet_status_prefix("13PS1:")
>dbLoadRecords("/usr/local/epics/r3.14.10/support/autosave/4-5/asApp/Db/save_restoreStatus.db", "P=13PS1:")
>iocInit()
>Starting iocInit
>## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
>## EPICS Base built Nov 29 2009
>[New Thread 0xb6534b90 (LWP 22452)]
>[New Thread 0xb64f3b90 (LWP 22453)]
>[New Thread 0xb6472b90 (LWP 22454)]
>[New Thread 0xb63f1b90 (LWP 22455)]
>[New Thread 0xb6370b90 (LWP 22456)]
>reboot_restore: entry for file 'auto_settings.sav'
>reboot_restore (v4.11): entry for file 'auto_settings.sav'
>reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
>*** restoring from './autosave/auto_settings.sav' at initHookState 5 (before record/device init) ***
>reboot_restore: done with file 'auto_settings.sav'
>*** restoring from './autosave/auto_settings.sav' at initHookState 6 (after record/device init) ***
>[New Thread 0xb5ef2b90 (LWP 22457)]
>[New Thread 0xb5cffb90 (LWP 22458)]
>[New Thread 0xb5c7eb90 (LWP 22459)]
>[New Thread 0xb5bfdb90 (LWP 22460)]
>[New Thread 0xb5b7cb90 (LWP 22461)]
>[New Thread 0xb5afbb90 (LWP 22462)]
>[New Thread 0xb5a7ab90 (LWP 22463)]
>[New Thread 0xb59f9b90 (LWP 22464)]
>2009/11/29 15:42:02.843 13PS1:cam1:PSFrameRate_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=64, value=0.000000
>2009/11/29 15:42:02.843 13PS1:cam1:Strobe1Delay_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=85, value=0.000000
>2009/11/29 15:42:02.843 13PS1:cam1:Strobe1Duration_RBV devAsynFloat64::process read error asynPortDriver:readFloat64: status=3, function=87, value=0.000000
>2009/11/29 15:42:02.843 prosilica:readParameters: error unsupported data type 1 and/or color mode 0
>2009/11/29 15:42:02.843 prosilica:getGeometry: error, status=3
>2009/11/29 15:42:02.843 prosilica:readParameters: error, status=3
>2009/11/29 15:42:02.843 prosilica:writeFloat64: error, status=3 function=44, value=0.010000
>2009/11/29 15:42:02.843 13PS1:cam1:AcquirePeriod devAsynFloat64 process error
>2009/11/29 15:42:02.844 prosilica:readParameters: error unsupported data type 1 and/or color mode 0
>2009/11/29 15:42:02.844 prosilica:getGeometry: error, status=3
>2009/11/29 15:42:02.844 prosilica:readParameters: error, status=3
>2009/11/29 15:42:02.844 prosilica:writeFloat64: error, status=3 function=43, value=1.000000
>2009/11/29 15:42:02.844 13PS1:cam1:AcquireTime devAsynFloat64 process error
>2009/11/29 15:42:02.844 prosilica:writeFloat64: error, status=3 function=27, value=1.000000
>2009/11/29 15:42:02.844 13PS1:cam1:Gain devAsynFloat64 process error
>2009/11/29 15:42:02.844 prosilica:writeFloat64: error, status=3 function=52, value=0.000000
>2009/11/29 15:42:02.844 13PS1:cam1:ShutterCloseDelay devAsynFloat64 process error
>2009/11/29 15:42:02.844 prosilica:writeFloat64: error, status=3 function=51, value=0.000000
>2009/11/29 15:42:02.844 13PS1:cam1:ShutterOpenDelay devAsynFloat64 process error
>2009/11/29 15:42:02.844 prosilica:writeFloat64: error, status=3 function=85, value=0.000000
>2009/11/29 15:42:02.844 13PS1:cam1:Strobe1Delay devAsynFloat64 process error
>2009/11/29 15:42:02.844 prosilica:writeFloat64: error, status=3 function=87, value=0.000000
>2009/11/29 15:42:02.844 13PS1:cam1:Strobe1Duration devAsynFloat64 process error
>2009/11/29 15:42:02.844 prosilica:writeFloat64: error, status=3 function=53, value=0.000000
>2009/11/29 15:42:02.844 13PS1:cam1:Temperature devAsynFloat64 process error
>2009/11/29 15:42:02.845 13PS1:cam1:Strobe1CtlDuration_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=86, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:SyncIn1Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=73, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:SyncIn2Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=74, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:SyncOut1Invert_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=77, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:SyncOut1Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=76, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:SyncOut2Invert_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=80, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:SyncOut2Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=79, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:SyncOut3Invert_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=83, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:SyncOut3Level_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=82, value=0
>2009/11/29 15:42:02.845 prosilica:readParameters: error unsupported data type 1 and/or color mode 0
>2009/11/29 15:42:02.845 prosilica:getGeometry: error, status=3
>2009/11/29 15:42:02.845 prosilica:readParameters: error, status=3
>2009/11/29 15:42:02.845 prosilica:writeInt32: error, status=3 function=24, value=1
>2009/11/29 15:42:02.845 13PS1:cam1:ArrayCallbacks devAsynInt32 process error
>2009/11/29 15:42:02.845 prosilica:writeInt32: error, status=3 function=12, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:AutoIncrement devAsynInt32 process error
>2009/11/29 15:42:02.845 prosilica:writeInt32: error, status=3 function=15, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:AutoSave devAsynInt32 process error
>2009/11/29 15:42:02.845 prosilica:writeInt32: error, status=3 function=36, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:ReverseX devAsynInt32 process error
>2009/11/29 15:42:02.845 prosilica:writeInt32: error, status=3 function=37, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:ReverseY devAsynInt32 process error
>2009/11/29 15:42:02.845 prosilica:writeInt32: error, status=3 function=47, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:ShutterControl devAsynInt32 process error
>2009/11/29 15:42:02.845 prosilica:writeInt32: error, status=3 function=86, value=0
>2009/11/29 15:42:02.845 13PS1:cam1:Strobe1CtlDuration devAsynInt32 process error
>2009/11/29 15:42:02.846 prosilica:readParameters: error unsupported data type 1 and/or color mode 0
>2009/11/29 15:42:02.846 prosilica:getGeometry: error, status=3
>2009/11/29 15:42:02.846 prosilica:readParameters: error, status=3
>2009/11/29 15:42:02.846 prosilica:writeInt32: error, status=3 function=77, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:SyncOut1Invert devAsynInt32 process error
>2009/11/29 15:42:02.846 prosilica:writeInt32: error, status=3 function=76, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:SyncOut1Level devAsynInt32 process error
>2009/11/29 15:42:02.846 prosilica:writeInt32: error, status=3 function=80, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:SyncOut2Invert devAsynInt32 process error
>2009/11/29 15:42:02.846 prosilica:writeInt32: error, status=3 function=79, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:SyncOut2Level devAsynInt32 process error
>2009/11/29 15:42:02.846 prosilica:writeInt32: error, status=3 function=83, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:SyncOut3Invert devAsynInt32 process error
>2009/11/29 15:42:02.846 prosilica:writeInt32: error, status=3 function=82, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:SyncOut3Level devAsynInt32 process error
>2009/11/29 15:42:02.846 13PS1:cam1:PSBadFrameCounter_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=72, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:PSFramesCompleted_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=65, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:PSFramesDropped_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=66, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:PSPacketsErroneous_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=67, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:PSPacketsMissed_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=68, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:PSPacketsReceived_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=69, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:PSPacketsRequested_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=70, value=0
>2009/11/29 15:42:02.846 13PS1:cam1:PSPacketsResent_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=71, value=0
>2009/11/29 15:42:02.847 prosilica:setGeometry: error, status=3
>2009/11/29 15:42:02.847 prosilica:readParameters: error unsupported data type 1 and/or color mode 0
>2009/11/29 15:42:02.847 prosilica:getGeometry: error, status=3
>2009/11/29 15:42:02.847 prosilica:readParameters: error, status=3
>2009/11/29 15:42:02.847 prosilica:writeInt32: error, status=3 function=28, value=1
>2009/11/29 15:42:02.847 13PS1:cam1:BinX devAsynInt32 process error
>2009/11/29 15:42:02.847 prosilica:writeInt32: error, status=3 function=29, value=1
>2009/11/29 15:42:02.847 13PS1:cam1:BinY devAsynInt32 process error
>2009/11/29 15:42:02.847 prosilica:writeInt32: error, status=3 function=10, value=1
>2009/11/29 15:42:02.847 13PS1:cam1:FileNumber_write devAsynInt32 process error
>2009/11/29 15:42:02.847 prosilica:writeInt32: error, status=3 function=30, value=0
>2009/11/29 15:42:02.847 13PS1:cam1:MinX devAsynInt32 process error
>2009/11/29 15:42:02.847 prosilica:writeInt32: error, status=3 function=31, value=0
>2009/11/29 15:42:02.847 13PS1:cam1:MinY devAsynInt32 process error
>2009/11/29 15:42:02.847 prosilica:writeInt32: error, status=3 function=19, value=0
>2009/11/29 15:42:02.847 13PS1:cam1:NumCapture devAsynInt32 process error
>2009/11/29 15:42:02.847 prosilica:writeInt32: error, status=3 function=41, value=1
>2009/11/29 15:42:02.847 13PS1:cam1:NumExposures devAsynInt32 process error
>2009/11/29 15:42:02.847 prosilica:writeInt32: error, status=3 function=42, value=1
>2009/11/29 15:42:02.848 13PS1:cam1:NumImages devAsynInt32 process error
>2009/11/29 15:42:02.848 prosilica:setGeometry: error, status=3
>2009/11/29 15:42:02.848 prosilica:readParameters: error unsupported data type 1 and/or color mode 0
>2009/11/29 15:42:02.848 prosilica:getGeometry: error, status=3
>2009/11/29 15:42:02.848 prosilica:readParameters: error, status=3
>2009/11/29 15:42:02.848 prosilica:writeInt32: error, status=3 function=32, value=1
>2009/11/29 15:42:02.848 13PS1:cam1:SizeX devAsynInt32 process error
>2009/11/29 15:42:02.848 prosilica:writeInt32: error, status=3 function=33, value=1
>2009/11/29 15:42:02.848 13PS1:cam1:SizeY devAsynInt32 process error
>2009/11/29 15:42:02.848 13PS1:cam1:Strobe1Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=84, value=0
>2009/11/29 15:42:02.848 13PS1:cam1:SyncOut1Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=75, value=0
>2009/11/29 15:42:02.848 13PS1:cam1:SyncOut2Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=78, value=0
>2009/11/29 15:42:02.848 13PS1:cam1:SyncOut3Mode_RBV devAsynInt32 process read error asynPortDriver:readInt32: status=3, function=81, value=0
>2009/11/29 15:42:02.848 prosilica:writeInt32: error, status=3 function=6, value=0
>2009/11/29 15:42:02.848 13PS1:cam1:ColorMode devAsynInt32 process error
>2009/11/29 15:42:02.848 13PS1:cam1:PSDriverType_RBV devAsynOctet: readIt failed asynPortDriver:readOctet: status=3, function=62, value=
>2009/11/29 15:42:02.848 13PS1:cam1:PSFilterVersion_RBV devAsynOctet: readIt failed asynPortDriver:readOctet: status=3, function=63, value=
>2009/11/29 15:42:02.848 prosilica:writeInt32: error, status=3 function=5, value=1
>2009/11/29 15:42:02.848 13PS1:cam1:DataType devAsynInt32 process error
>2009/11/29 15:42:02.848 prosilica:writeInt32: error, status=3 function=14, value=0
>2009/11/29 15:42:02.848 13PS1:cam1:FileFormat devAsynInt32 process error
>2009/11/29 15:42:02.865 prosilica:readParameters: error unsupported data type 1 and/or color mode 0
>2009/11/29 15:42:02.866 prosilica:getGeometry: error, status=3
>2009/11/29 15:42:02.866 prosilica:readParameters: error, status=3
>2009/11/29 15:42:02.866 prosilica:writeInt32: error, status=3 function=18, value=0
>2009/11/29 15:42:02.866 13PS1:cam1:FileWriteMode devAsynInt32 process error
>2009/11/29 15:42:02.866 prosilica:readParameters: error unsupported data type 1 and/or color mode 0
>2009/11/29 15:42:02.866 prosilica:writeInt32: error, status=3 function=38, value=0
>2009/11/29 15:42:02.866 13PS1:cam1:FrameType devAsynInt32 process error
>2009/11/29 15:42:02.866 prosilica:writeInt32: error, status=3 function=39, value=2
>2009/11/29 15:42:02.866 13PS1:cam1:ImageMode devAsynInt32 process error
>2009/11/29 15:42:02.866 prosilica:writeInt32: error, status=3 function=50, value=0
>2009/11/29 15:42:02.866 13PS1:cam1:ShutterMode devAsynInt32 process error
>2009/11/29 15:42:02.866 prosilica:writeInt32: error, status=3 function=84, value=0
>2009/11/29 15:42:02.866 13PS1:cam1:Strobe1Mode devAsynInt32 process error
>2009/11/29 15:42:02.866 prosilica:writeInt32: error, status=3 function=75, value=0
>2009/11/29 15:42:02.866 13PS1:cam1:SyncOut1Mode devAsynInt32 process error
>2009/11/29 15:42:02.866 prosilica:writeInt32: error, status=3 function=78, value=0
>2009/11/29 15:42:02.866 13PS1:cam1:SyncOut2Mode devAsynInt32 process error
>2009/11/29 15:42:02.866 prosilica:writeInt32: error, status=3 function=81, value=0
>2009/11/29 15:42:02.866 13PS1:cam1:SyncOut3Mode devAsynInt32 process error
>2009/11/29 15:42:02.866 prosilica:writeInt32: error, status=3 function=40, value=0
>2009/11/29 15:42:02.866 13PS1:cam1:TriggerMode devAsynInt32 process error
>[New Thread 0xb5978b90 (LWP 22465)]
>[New Thread 0xb5937b90 (LWP 22466)]
>The CA server's beacon address list was empty after initialization?
>[New Thread 0xb5916b90 (LWP 22467)]
>iocRun: All initialization complete
>#asynSetTraceMask("PS1",0,1)
># save things every thirty seconds
>create_monitor_set("auto_settings.req", 30,"P=13PS1:,D=cam1:")
>[New Thread 0xb58d5b90 (LWP 22468)]
>[New Thread 0xb5854b90 (LWP 22469)]
>[Thread 0xb7ee1b90 (LWP 22432) exited]
>[Thread 0xb6a9eb90 (LWP 22435) exited]
>[New Thread 0xb7ee1b90 (LWP 22470)]
>[Thread 0xb69dbb90 (LWP 22438) exited]
>[Thread 0xb67ffb90 (LWP 22441) exited]
>[New Thread 0xb69dbb90 (LWP 22471)]
>[Thread 0xb673cb90 (LWP 22444) exited]
>[Thread 0xb66bab90 (LWP 22446) exited]
>[Thread 0xb6638b90 (LWP 22448) exited]
>[Thread 0xb65b6b90 (LWP 22450) exited]
>fc10 epics> [New Thread 0xb65b6b90 (LWP 22472)]
>Program received signal SIGSEGV, Segmentation fault.
>[Switching to Thread 0xb749fb90 (LWP 22434)]
>0x080fdb23 in SIGAction ()
>(gdb) bt
>#0 0x080fdb23 in SIGAction ()
>#1 0x08248bdd in ignoreSigAlarm (signal=14) at ../../../src/libCom/osi/os/posix/osdSignal.cpp:109
>#2 <signal handler called>
>#3 0x00110416 in __kernel_vsyscall ()
>#4 0x007543d1 in select () from /lib/libc.so.6
>#5 0x080fdf0e in pPvMultiplexer::Body ()
>#6 0x08101af0 in _ThreadFunction ()
>#7 0x0082651f in start_thread (arg=0xb749fb90) at pthread_create.c:297
>#8 0x0075c04e in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:130
>(gdb)
>======= At 2009-11-22, 08:41:46 you wrote: =======
>>I just double-checked my system and I realized actually ran into the same problem with libnet 1.1.2.1-11 a couple of years ago. I fixed it by simply removing the "inline" keyword from that line in libnet-functions.h.
>>I looked at a more recent version of libnet (1.1.4-3) and the inline keyword is not present in that version of libnet-functions.h
>>Mark
>>From: [email protected] on behalf of Bruce Hill
>>Sent: Fri 11/20/2009 8:51 PM
>>To: [email protected]
>>Cc: tech-talk
>>Subject: Re: error building mca6-11
>>I had a similar problem where I needed to compile some code
>>I was sharing with a non-epics app and I needed to compile it
>>without -ansi.
>>Turning it off in epics base config files is asking for trouble as it
>>will affect all compiles of base, modules, IOC's, etc.
>>Since -ansi is selecting the language standard, you can't just turn it off
>>with a compile flag. Instead, you have to select a different language
>>standard. The default gnu std for c files is gnu89, but others are
>>available as well, such as c89, c99, gnu99, etc. See the gcc man page
>>for details.
>>For my directory that had this problem, I added the following line in that
>>directory's Makefile after including $(TOP)/configure/CONFIG.
>> USR_CFLAGS += -std=gnu99
>>- Bruce Hill
>>Silver wrote:
>> hi, Michael:
>> so how to solve it? close the ansi switch in epics base's configure files? will it influence the base?
>> ======= At 2009-11-20, 22:41:31 you wrote: =======
>> This is an '-ansi' problem.
>> On my Debian system (libnet 1.1.2.1-2) line 1432 of libnet-functions.h
>> looks like
>> inline u_int32_t
>> The 'inline' keyword isn't part of ANSI C89 and can't be used when
>> compiling with '-ansi', which EPICS Base does by default.
>> Michael Davidsaver
>> NSLSII Controls Group
>> Brookhaven National Lab
>> -----Original Message-----
>> From: [email protected] [mailto:tech-talk-
>> [email protected]] On Behalf Of Silver
>> Sent: Friday, November 20, 2009 12:28 AM
>> To: tech-talk
>> Subject: error building mca6-11
>> hi,
>> when I tried to compile the mcaR6-11/10, I met following errors:
>> /usr/bin/gcc-4.2 -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -
>> D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -
>> D_REENTRANT -ansi -O3 -Wall -g `libnet-config --defines`
>> -m32
>> -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -
>> I../../../include -I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-
>> 12/include
>> -I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include
>> -I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include -
>> I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include -
>> I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include -
>> I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include -
>> I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux -
>> I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include -
>> I/usr/local/epics/r3.14.10/base/include/os/Linux -
>> I/usr/local/epics/r3.14.10/base/include ../nmc_comm_subs_1.c
>> In file included from /usr/include/libnet.h:124,
>> from ../nmc_sys_defs.h:56,
>> from ../nmc_comm_subs_1.c:69:
>> /usr/include/./libnet/libnet-functions.h:1432: error: expected '=',
>> ',', ';', 'asm' or '__attribute__' before 'u_int32_t'
>> make[3]: *** [nmc_comm_subs_1.o] Error 1
>> make[3]: Leaving directory
>> `/usr/local/epics/r3.14.10/modules/soft/mca/6-
>> 11/mcaApp/CanberraSrc/O.linux-x86'
>> make[2]: *** [install.linux-x86] Error 2
>> make[2]: Leaving directory
>> `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
>> make[1]: *** [CanberraSrc.install] Error 2
>> make[1]: Leaving directory
>> `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
>> make: *** [mcaApp.install] Error 2
>> root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
>> Any suggestion? thanks a lot.
>> ps, I use ubuntu, libnet1 with apt-get install ,not from source
>> compilation.
>> Best regards
>> Geyang 2009-11-20
>> Best regards
>> Geyang 2009-11-21
>>Bruce Hill
>>Member Technical Staff
>>SLAC National Accelerator Lab
>>2575 Sand Hill Road M/S 94
>>Menlo Park, CA 94025
>Best regards
>Geyang 2009-11-28
Best regards
Geyang 2009-11-28
- RE: RE: RE: error building mca6-11 Mark Rivers
- Re: RE: RE: RE: error building mca6-11 Silver
- error building mca6-11 Silver
- RE: error building mca6-11 Davidsaver, Michael
- Re: RE: error building mca6-11 Silver
- Re: error building mca6-11 Bruce Hill
- RE: error building mca6-11 Mark Rivers
Mobus R2-0 available Mark Rivers
<2009>
2025
<2009>
2025
