Just for completeness and to confuse you....
The change Janet suggests will build HOST prods and libraries for
linux-xscale_be for all applications, everywhere.
(To avoid conflicts with version upgrades, it should rather be done in a
copy of that file, called .../configure/CONFIG_SITE.Common.linux-xscale_be.)
If you want this behavior only for one application, you could remove the
_HOST qualifier from the LIBRARY_HOST and PROD_HOST definitions in that
application's Makefiles, which will build only this application for HOST
and all IOC type architectures.
If you want only this application to build on the HOST and only one of
your IOC target architectures, you could leave the *_HOST definitions in
and add a similar *_IOC_linux-xscale_be definition to each one.
Ralph
Janet Anderson wrote:
R3.14.11 base contain a configure/CONFIG.Common.linux-xscale_be file.
It is set up to build only IOC prods and libraries.
Comment out the line "VALID_BUILDS = Ioc" to build both HOST and IOC
David Dudley wrote:
I have a project where I need to cross build some of the EPICS
extensions for another architecture.
Specifically, I want to build the ChannelArchiver to run on a remote
Linux host.
I already have the IOS compiled for the host (linux-xscale_be), and
it works well, with all the libraries and programs functional on that
architecture, but to make the machine I’m setting up an independent
system, I need to run the ChannelArchiver as well on that device.
I defined ‘CROSS_COMPILER_TARGET_ARCHS’ in the extensions configure
directory to ‘linux-xscale_be’, and when I build, I create a
xscale_be bin directory, however the build system doesn’t pick up the
target build tools, so it’s building 2 copies of the host programs.
What do I adjust to make the extensions build system pick up the
proper toolset?
David Dudley
- Cross Building Extensions David Dudley
- Re: Cross Building Extensions Janet Anderson
camonitor and caget - displaying unsigned longs in hexadecimal Allison, Stephanie
<2009>
2025
<2009>
2025
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
