1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM on Cygwin
To: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>, Tech-talk <[email protected]>
Date: Wed, 09 Dec 2009 11:17:00 -0500
Pawel,
EDM will never, ever build on cygwin.
Note that a new initiative is in the works to build control system gui tools using the eclipse
RCP platform. This will give you access from windows.
There is also an older display manager, MEDM, which I believe will compile in a windows environment with certain 3rd party X Windows tools. I don't know the details but someone
on the tech-talk list may be able to help.
John Sinclair
Pawel Kowalski - BiRa Systems Inc. wrote:
Hello,
I am having an issue with getting EDM to compile on cygwin. I noticed that in the EDM documentation it says that LessTif is not recommended; but that seems to be the only option available with cygwin as I can’t find the OpenMotif package. Is this my issue or am I doing something else wrong? I also saw that the makefiles under EDM set SHARED_LIBRARIES = YES, is this a problem under cygwin?
I attached the make log, help would be appreciated.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com <http://www.bira.com>
*Phone:*                   505-881-8887
*Fax:*                       505-888-0651
*Address:*                2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
Pawel Kowalski@bira-a4f57d2df6 /epics/base/extensions/src/edm
$ make
make -C ./util install
make[1]: Entering directory `/epics/base/extensions/src/edm/util'
make -C O.cygwin-x86 -f ../Makefile TOP=../../../.. T_A=cygwin-x86 install
make[2]: Entering directory `/epics/base/extensions/src/edm/util/O.cygwin-x86'
make[2]: *** No rule to make target `../O.Common/os.h', needed by `inc'.  Stop.
make[2]: Leaving directory `/epics/base/extensions/src/edm/util/O.cygwin-x86'
make[1]: *** [install.cygwin-x86] Error 2
make[1]: Leaving directory `/epics/base/extensions/src/edm/util'
make: *** [util.install] Error 2
RE: EDM on Cygwin Mark Rivers
EDM on Cygwin Pawel Kowalski - BiRa Systems Inc.
Prev: EDM on Cygwin Pawel Kowalski - BiRa Systems Inc.
Next: RE: EDM on Cygwin Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
