1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Odd widget layout in EDM on OS X
To: Eric Norum <[email protected]>
Cc: TECHTALK Tech-Talk <[email protected]>
Date: Wed, 09 Dec 2009 16:48:50 -0500
Hi Eric,
Several users at SNS have been running EDM (64 bit Intel) with Mac OS X 10.6.2 without problems. We are using Open Motif 2.3.1-1_2 and EDM 1-12-4.
best regards,
tom
On Dec 9, 2009, at 4:33 PM, Eric Norum wrote:
I downloaded and built EDM (edm-1-12-24.tgz) on my OS X (10.6.12) machine.   I'm using Open Motif 2.3.2-2.  There appears to be something wrong with the spacing, though.  For example, here's what the Button Properties window looks like when I try to create a new button.  As you can see, it's going to be a little tricky to set the properties!
Any ideas as to where to look for a solution?
<PastedGraphic-2.tiff><ATT00001..txt>
______________
Tom Pelaia, Ph.D.
Application Programming Team Leader
Accelerator Physics Group
Research Accelerator Division
Spallation Neutron Source
Oak Ridge National Lab
homepage: http://www.ornl.gov/~t6p
Odd widget layout in EDM on OS X Eric Norum
Prev: Odd widget layout in EDM on OS X Eric Norum
Next: Re: Fwd: CA link behavior Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Odd widget layout in EDM on OS X Noboru Yamamoto
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
