1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Any News on EPICS 3.14.11 with vxWorks 6.7
To: "'Ernest L. Williams Jr.'" <[email protected]>
Cc: "'Yves Lussignol'" <[email protected]>, "'Jean-Francois Gournay'" <[email protected]>, "'Eric Bjorklund'" <[email protected]>, [email protected]
Date: Wed, 9 Dec 2009 15:36:55 -0700
Ernest,
The following code reproduces the vxWorks 6.6 gcc compiler bug (as seen with
EPICS R3.14.11).
[hill@integrity cas]$
/ade/vxWorks/6/gnu/4.1.2-vxworks-6.6/x86-linux2/bin/ccppc -c
-DCPU=PPC604  -DvxWorks      -O2   -Wall     -mcpu=604 -mstrict-align
-fno-implicit-fp    -fno-builtin   -MMD -I. -I../O.Common -I. -I..
-I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket
-I../../../../src/cas/generic/st -I../../../../src/cas/../ca
-I../../../../include/os/vxWorks -I../../../../include
-I/ade/vxWorks/6/vxworks-6.6/target/h
-I/ade/vxWorks/6/vxworks-6.6/target/h/wrn/coreip -v
Using built-in specs.
Target: powerpc-wrs-vxworks
Configured with: /scratch/nathan/vxworks/src/gcc-4.1/configure
--build=i686-pc-linux-gnu --host=i686-pc-linux-gnu
--target=powerpc-wrs-vxworks --enable-threads --disable-libmudflap
--disable-libssp --disable-libgomp --disable-libstdcxx-pch
--enable-sjlj-exceptions --disable-hosted-libstdcxx
--enable-version-specific-runtime-libs --with-gnu-as --with-gnu-ld
--enable-languages=c,c++ --disable-shared --disable-hosted-libstdcxx
--with-cxxabi=/scratch/nathan/vxworks/src/dinkum-20021215/include
--with-pkgversion='Wind River VxWorks G++ 4.1-82'
[email protected] --disable-nls --prefix=/opt/codesourcery
--exec-prefix='/opt/codesourcery/x86-linux2'
--libdir='/opt/codesourcery/lib'
--program-transform-name='s,^gcc$,cc,;s,$,ppc,'
--with-gxx-include-dir=''\''/opt/codesourcery/'\''include/c++/4.1'
--with-license=/scratch/nathan/vxworks/powerpc/obj/host-libs-4.1-82-powerpc-
wrs-vxworks-i686-pc-linux-gnu/usr --with-csl-license-version=20071015
--with-csl-license-feature=gcc_Power_VxWorks
--enable-poison-system-directories
Thread model: vxworks
gcc version 4.1.2 (Wind River VxWorks G++ 4.1-82)
-I/ade/vxWorks/6/vxworks-6.6/target/h/wrn/coreip tmp.cc
tmp.cc: In member function 'DblRet Cat::meow()':
tmp.cc:49: error: unable to find a register to spill in class 'FLOAT_REGS'
tmp.cc:49: error: this is the insn:
(insn:HI 30 29 85 3 (set (reg:DF 121 [ D.1042 ])
        (mem/s/c:DF (plus:SI (reg/f:SI 113 sfp)
                (const_int 8 [0x8])) [9 D.1040+0 S8 A64])) 301
{*movdf_hardfloat32} (insn_list:REG_DEP_ANTI 29 (nil))
    (nil))
------------------------snip-snip------------------
class DblRet {
public:
    DblRet ();
private:
    double delay;
struct Cow {
    void milk ();
private:
    void moo ();
class Fish
public:
    Fish ( int & );
    ~Fish ();
inline Fish :: Fish ( int & )
inline Fish :: ~Fish ()
inline void Cow :: milk ()
    extern int & fishy;
    Fish fish ( fishy );
    moo ();
class Cat {
public:
    DblRet meow ();
private:
    Cow * m_pCow;
DblRet Cat :: meow ()
    m_pCow->milk ();
    return DblRet ();
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:[email protected]]
> Sent: Wednesday, December 09, 2009 12:46 PM
> To: Jeff Hill
> Cc: 'Andrew Johnson'; 'Yves Lussignol'; [email protected]; 'Jean-
> Francois Gournay'; [email protected]; 'Eric Bjorklund'; Ernest L.
> Williams Jr.
> Subject: Re: Any News on EPICS 3.14.11 with vxWorks 6.7
> Jeff Hill wrote:
> > Hi Ernest,
> > Executive summary:
> > 1) Apparently, GCC doesn?t fail with the MVME550 but this is very
> similar
> > processor. What -mcpu flag was used with the MVME5500?
> Not sure, if they have a separate CONFIG file for MVME5500
> What we have with the distribution of BASE from APS is the following:
> <>/configure/os/CONFIG.Common.vxWorks-ppc604
> The flag is :
> ARCH_DEP_CFLAGS_4 = -mcpu=604 -mstrict-align -fno-implicit-fp
> > 2) I will need to try to reproduce it here with our vxWorks 6.6. That
> will
> > require installation of EPICS R3.14.11 onto a new host here.
> Okay, be sure to use the latest GNU Compiler patches from Windriver:
> > 3) I wonder if -mcpu=604e or -mcpu=7450 would a closer match to the
> board;
> > perhaps that?s worth a try.
> I tried both options; still does not work. Fails the same way.
> > Sorry about the delay responding, Los Alamos was, for all practical
> > purposes, in stasis yesterday due to snow, wind, and power outages (I
> spent
> > most of the day shoveling out three driveways).
> > A quick review of the current situation is in order. There was a no-
> altivec
> > flag for the C++ compiler that might have helped, but it didn?t, and now
> we
> > see that the issue does not occur with the MVME5500 but does occur with
> the
> > MVME6600. The MVME5500 has an MPC7455 processor chip and the MVME6100
> has an
> > MPC7457 processor chip. We are using -mcpu=604 when the compiler fails,
> and
> > I am not sure what -mcpu option was used for the MVME5500 when it did
> > compile. Perhaps -mcpu=604e or -mcpu=7450 would be worth trying?
> Again, I tried the different mcpu flags that you recommended. Still no
> change; build fails.
> By the way build for PPC603 architecture builds just fine. :)
> I am only having a problem with PPC604
> > http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MPC7457
> > http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MPC7455
> > I don?t claim to have read up on the subtle differences between these
> chips.
> > Nevertheless, the compiler should produce object code for the supported
> CPU
> > architecture that we select so we have a compiler bug; we are just
> looking
> > for a workaround when selecting different architectures.
> I need some work-around in the cas source code; I definitely need this
> because of the PV Gateway dependencies.
> > I _have_ tried to reproduce this in a small code but this is time
> consuming
> > because we have been using Ernest's compiler to test. I will need to try
> to
> > reproduce it here.
> > Jeff
> >> Sent: Tuesday, December 08, 2009 10:27 AM
> >> To: Jeff Hill
> >> Cc: Andrew Johnson; Yves Lussignol; [email protected]; Jean-
> Francois
> >> Gournay; [email protected]; Ernest L. Williams Jr.
> >> Subject: Any News on EPICS 3.14.11 with vxWorks 6.7
> >> Hi Jeff,
> >> Just wanted to follow up on the issue with vxWorks GNU compiler:
> >> I don't understand why our colleagues don't see this problem?
> >> /afs/slac/package/vxworks/devel/6.7/gnu/4.1.2-vxworks-6.7/x86-
> >> linux2/bin/ccppc
> >> -c            -DCPU=PPC604  -DvxWorks -DBSD=44     -g   -Wall
> >> -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall    -fno-builtin
> >> -DBSD=44  -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic
> >> -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st
> >> -I../../../../src/cas/../ca -I../../../../include/os/vxWorks
> >> -I/afs/slac/package/vxworks/devel/6.7/vxworks-6.7/target/h
> >> -I/afs/slac/package/vxworks/devel/6.7/vxworks-6.7/target/h/wrn/coreip
> >> ../../../../src/cas/generic/st/casStreamOS.cc
> >> In file included from
> >> /afs/slac/package/vxworks/devel/6.7/vxworks-6.7/target/h/taskLib.h:257,
> >>                  from
> >> 6.7/target/h/private/selectLibP.h:24,
> >>                  from
> 6.7/target/h/selectLib.h:75,
> >>                  from ../../../../include/os/vxWorks/osdSock.h:35,
> >>                  from ../../../../include/osiSock.h:21,
> >>                  from ../../../../include/fdManager.h:28,
> >>                  from ../../../../src/cas/generic/st/casStreamOS.cc:18:
> 6.7/target/h/vsbConfig.h:42:2:
> >> warning: #warning "VxWorks Source Build (VSB) project not specified;
> >> using default VxWorks UP configuration under
> >> $WIND_BASE/target/lib/h/config"
> >> ../../../../src/cas/generic/st/casStreamOS.cc: In member function
> >> 'virtual epicsTimerNotify::expireStatus casStreamIOWakeup::expire(const
> >> epicsTime&)':
> >> ../../../../src/cas/generic/st/casStreamOS.cc:283: error: unable to
> find
> >> ../../../../src/cas/generic/st/casStreamOS.cc:283: error: this is the
> >> insn:
> >> (insn 162 161 163 9 ../../../../src/cas/generic/st/casStreamOS.cc:280
> >> (set (reg:DF 119 [ D.21342 ])
> >>                 (const_int 24 [0x18])) [0 D.21330+0 S8 A64])) 301
> >> {*movdf_hardfloat32} (nil)
> >>     (nil))
> >> ../../../../src/cas/generic/st/casStreamOS.cc:283: confused by earlier
> >> errors, bailing out
> >> make[4]: *** [casStreamOS.o] Error 1
> >> make[4]: Leaving directory
> >> `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-
> >> 11/src/cas/build/O.vxWorks-ppc604_long'
> >> make[3]: *** [install.vxWorks-ppc604_long] Error 2
> >> make[3]: Leaving directory
> >> 11/src/cas/build'
> >> make[2]: *** [build.install] Error 2
> >> make[2]: Leaving directory
> >> `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-11/src/cas'
> >> make[1]: *** [cas.install] Error 2
> >> make[1]: Leaving directory
> >> `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-11/src'
> >> Thanks,
> >> Ernest
Re: Any News on EPICS 3.14.11 with vxWorks 6.7 Ernest L. Williams Jr.
Prev: Re: Fwd: CA link behavior Andrew Johnson
Next: Re: Odd widget layout in EDM on OS X Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Odd widget layout in EDM on OS X Eric Norum
Next: Re: Any News on EPICS 3.14.11 with vxWorks 6.7 Ernest L. Williams Jr.
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
