I plan on making a couple of changes to the ASYN TCP port driver. Here's the salient portion of the release notes:
drvAsynIPPort
1) A return of 0 from a read of a TCP stream is treated as an END condition rather than as an error. This makes it easier to handle devices that close the connection at the end of a reply.
2) Support has been added for devices such as web servers that require a connect at the beginning of each transaction. To enable this behaviour, specify "http" as the protocol in the drvAsynIPPortConfigure command and ensure that each transaction ends with a read that detects the broken connection from the device. Note that the device will always appear connected. The connect/disconnect around each transaction is handled within the drvAsynIPPort driver.
I hope that these changes are neither too controversial nor too disruptive. The first one I believe falls under the "principle of least surprise" and the second takes effect only when changes are made to a startup file command.
Eric Norum
[email protected]
P.S. Thanks go out to Marty Kraimer and Mark Rivers for their help in making these changes.
Re: Reading an array of strings from a Waveform record Andrew Johnson
RE: Rethinking asyn motor drivers matthew.pearson
<2009>
2025
Re: EDM GUI disable/enable Ralph Lange
displaying areaDetector Video with EDM or MEDM John Dobbins
<2009>
2025
