1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Remote I/O & RT linux
To: [email protected]
Cc: [email protected], [email protected]
Date: Thu, 17 Dec 2009 12:45:32 -0600
at aps, the ebricks are using a standard linux kernel (2.6.19) (vector linux distribution) with a real-time patch provided by the osadl group (http://www.osadl.org) ... *all free* ... we are happy with it and
has made a difference with respect to interrupt response time.
/david
[email protected] wrote:
I've noticed several people mentioning real time linux. Are proprietary
real time builds widely used, or is standard free linux with real time
patches generally used?
Are there hardware platforms that are more suitable for RT linux?
(specific CPUs or chipsets?)
Cheers,
Matthew
-----Original Message-----
[mailto:[email protected]] On Behalf Of Richard Farnsworth
Sent: 17 December 2009 00:34
To: Rees, Nick (DLSLtd,RAL,DIA)
Subject: RE: Remote I/O
Nick,
At the Australian synchrotron, we use Ethernet as a field bus also.
Ethernet is not deterministic in theory , but with clever networking you
can get around most of the issues in practice. We separate the
accelerator networks from the beamlines (and other places). We use
gateways if we need data transfer.
Our primary PLC's use Modicon premium PLCs (Schneider) and a Modbus/IP
driver (Not Mark Rivers one though, although it may have a common
ancestor). Also our PILZ safety system PLC's, and a number of other
systems use Modbus. We do have some other Ethernet drivers for a few
variant PLC's (Siemens and Rockwell and our building systems).
One problem we are getting into is that the keep alive chatter
(Broadcast) on the PLC's is starting to impact network performance and
we may look at separate networks (And second network cards) on certain
PLC's in the future.
Our IOC's talk via Moxa's terminal servers to serial devices, RS232
primarily, but also RS422 and RS485. We also have a number of Cosylab
supplied PC/104 soft IOC's with RS485 daughter cards.
Almost no VME, most analog and digital I/O is performed using PCI I/O
cards on a mixture of Soft IOC's and some running Redhawk real time
Linux. We will be removing them in the near future and just using
standard Linux.
Temperature measurements are done in part using a tiny (cheap) Modbus
device called an "ITM". More details if you need that. We recently
replaced most of them as they (ironically) got too hot wher we mounted
them and they failed.
VME (as a power supply/crate) is only in use on the timing system and
one or two special devices. We use Linux IOC's and a Struck VME to PCI
bridge for the odd VME only case.
I'd like to say no VxWorks, but I've discovered recently that the
Modicon premiums actually use VxWorks internally.
A strong emphasis on Linux throughout, the major exceptions being our
PLC development tools and the Dipole power supply uses (Ahhchoo, Spit,
Ting) Windows CE. Even our GUI's use wine on Linux to run the windows
executables we develop with Borland Delphi (We will change to QT over
time).
Richard Farnsworth | Head of Computing | Australian Synchrotron
p: (03) 8540 4118 | f: (03) 8540 4200 | m: 0421 082 147
[email protected] | www.synchrotron.org.au 800
Blackburn Road, Clayton, Victoria 3168
<br>This message and any attachments may contain proprietary or
confidential information. If you are not the intended recipient or you
received the message in error, you must not use, copy or distribute the
message. Please notify the sender immediately and destroy the original
message. Thank you.
David M. Kline                    [email protected]
Argonne National Laboratory
Argonne IL, 60439                       630.252.8639
Advanced Photon Source, X-ray Science Division
Optics and Detectors Group
                  Detectors-R-Us
Re: Remote I/O & RT linux Kazuro FURUKAWA
Remote I/O nick.rees
Re: Remote I/O Dave Reid
RE: Remote I/O Richard Farnsworth
RE: Remote I/O & RT linux matthew.pearson
Prev: Re: Remote I/O Dave Reid
Next: New home for asyn Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Remote I/O & RT linux matthew.pearson
Next: Re: Remote I/O & RT linux Kazuro FURUKAWA
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
