Subject: |
Re: Compiling alh, MEDM on Snow Leopard (10.6.2) |
Steve Shoaf <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Mon, 21 Dec 2009 08:08:54 -0600 |
Bertrand,
gcc on Snow Leopard defaults to 64-bit compiling, Xcode projects apparently default to 32-bit. As of R3.14.11 EPICS base does not have support in the build files for darwin-x86_64. The "file is not of required architecture" came up when I was compiling some of my darwin R3.14.11 soft ioc's at the APS when I was upgraded to Snow Leopard. If you add the following to your CONFIG_SITE file, then gcc will build and link for 32-bit.
ARCH_DEP_CFLAGS += -m32 -arch i386
ARCH_DEP_LDFLAGS += -arch i386
Hope that resolves your issue,
Steve Shoaf
On Dec 20, 2009, at 9:58 AM, Bertrand H.J. Biritz wrote:
> Dear Tech-Talk,
> It's the holiday season which means new computer (for my dad this time) and also compiling code :)
> So I tried installing EPICS et al. on a MacBook Pro (2.53 GHz) running 10.6.2 with MacPorts 1.8.1.
> EPICS 3.14.11 went fine, although I needed to deactivate readline (6.0.000_2+darwin) as it caused an error – hopefully a problem on their end as the package is still in dev, but just in case here is the error message
> <snip>
> ../../../../bin/darwin-x86/antelope -l -d ../parse.y
> dyld: Symbol not found: _rl_insert
> Referenced from: /Users/Superior/Documents/EPICS/base-3-14-11/lib/darwin-x86/libCom.3.14.11.dylib
> Expected in: flat namespace
> <snip>
> When I try to compile the latest version of the alarm handler or MEDM I get the following error message:
> <snip>
> ld: warning: in /opt/local/lib/libXmu.dylib, file is not of required architecture
> ld: warning: in /opt/local/lib/libXm.dylib, file is not of required architecture
> ld: warning: in /opt/local/lib/libXt.dylib, file is not of required architecture
> ld: warning: in /opt/local/lib/libX11.dylib, file is not of required architecture
> Undefined symbols:
> "_XtAppAddActions", referenced from:
> _awRowWidgets in awAlh.o
> <snip>
> I double checked the CONFIG_SITE.darwin-x86.darwin-x86 file to make sure it is looking in the correct locations:
> # XDarwin
> X11_LIB=/usr/X11R6/lib
> X11_INC=/usr/X11R6/include/X11
> XPM_LIB=/usr/X11R6/lib
> XPM_INC=/usr/X11R6/include/X11
> # Fink OpenMotif
> #MOTIF_LIB=/sw/lib
> #MOTIF_INC=/sw/include
> # DarwinPorts OpenMotif
> MOTIF_LIB=/opt/local/lib
> MOTIF_INC=/opt/local/include
> Looking in the XDarwin directory there are three of the four .dylib libraries (libXm.dylib isn't there).
> Does someone have an idea of why the compilation is failing? Is it due to the X11 not being the latest version? On my PowerBook I have XQuartz 2.4.0 installed, but the XQuartz project said there would be a separate release called 2.4.1 for Snow Leopard.
> Thanks,
> Bertrand
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Pelaia II, Tom
- Compiling alh, MEDM on Snow Leopard (10.6.2) Bertrand H.J. Biritz
<2009>
2025
<2009>
2025
