Hi Paul,
You are correct, drvAsynIPServerPortConfigure can only handle TCP, and the documentation is wrong.
Eric Norum looked at adding UDP support to this code back in December. He concluded it was a fairly big job, but he did fix the sscanf problem for the next release. If you or someone else wants to add UDP support that would be great!
Sent: Wed 1/20/2010 2:59 AM
To: EPICS tech-talk
Subject: drvAsynIPServerPortConfigure
Hello,
The asyn documentation says that drvAsynIPServerPortConfigure can be a
TCP or UDP server but the source code in
asyn/drvAsynSerial/drvAsynIPServerPort.c does a
listen(tty->fd, tty->maxClients);
There is no recvfrom call so surely this is TCP only?
Also this code below fails to convert the protocol string in the string
"localhost:9600 udp" because the format string uses %ud which looks for
an unsigned integer followed by a 'd'. It should be just "%u". This
stops it from ever seeing the "udp" protocol specifier. This exists in
all of the version of asyn I have looked at (4-9 to 4-12).
* Parse configuration parameters
protocol[0] = '\0';
if (((cp = strchr(serverInfo, ':')) == NULL)
|| (sscanf(cp, ":%ud %5s", &tty->portNumber, protocol) < 1))
printf("drvAsynIPPortConfigure: \"%s\" is not of the form
\"<host>:<port>[protocol]\"\n",tty->serverInfo);
ttyCleanup(tty);
return -1;
Would it be possible to use stream device to handle incoming UDP data?
Paul.
- drvAsynIPServerPortConfigure Paul Hamadyk
Ipac with VIPC616 wmoore
<2010>
<2010>
