1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: caSnooper output
To: <[email protected]>
Date: Fri, 22 Jan 2010 08:43:07 -0800
When I use camonitor to check a PV, I get the following error message:
[dt100@tsdaq1 ~]$ camonitor ACQ196_310_UPTIME
ACQ196_310_UPTIME              *** Not connected (PV not found)
I have checked the IOC server is running properly. Then I try to use caSnooper to trouble-shoot. Here is the result:
[dt100@tsdaq1 linux-x86]$ ./caSnooper -t30 -p4 -c0
Starting CaSnooper 2.1.2.1 (8-10-2007) at Jan 22 08:27:18
EPICS 3.14.11
Individual Name is CaSnoop.test
Internal PV names are not being published
CaSnooper terminating after 30.01 seconds [0.50 minutes]
  Data collected for 30.01 seconds [0.50 minutes]
Jan 22 08:27:48:
There were 20 requests to check for PV existence for 2 different PVs.
  Max(Hz):   0.33
  Mean(Hz):  0.33
  StDev(Hz): 0.33
PVs with top 2 requests:
   1 192.168.1.1:44539              ACQ196_310_UPTIME                 0.33
   2 tsdaq1.gat.com:44539           ACQ196_310_UPTIME                 0.33
Connection status for top 2 PVs after 10.00 sec:
Questions:
1)      The IP address 192.168.1.1 and tsdaq1.gat.com of the two requests are the address of the client computer. The computer has two Ethernet port. Are the ip addresses all right?
2)      Should there be a valid request with the default port number 5064 instead of the big number 44539?
Thank you very much for your help in advance.
Caizhen
Re: caSnooper output Andrew Johnson
RE: caSnooper output Jeff Hill
Prev: info about VI to get waveform Clelia Scudellaro
Next: Re: caSnooper output Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: info about VI to get waveform Pawel Kowalski - BiRa Systems Inc.
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
