1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: cross compiling base on linux for win32
To: "Martin Konrad" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Mon, 8 Feb 2010 11:30:15 -0500
Hi Martin,
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Martin Konrad
> Sent: Sunday, February 07, 2010 7:30 AM
> To: EPICS tech-talk
> Subject: cross compiling base on linux for win32
> Hi,
> I just succeeded in cross compiling base and my IOC for win32-x86 on
> linux-x86 and linux-x86_64 using MinGW.
> For all of you who want to give it a try, here is what I did:
> 1. Copy the attached files to <base>/configure/os/ 2. Set
> CROSS_COMPILER_TARGET_ARCHS=win32-x86-mingw in
> <base>/configure/CONFIG_SITE 3. cd <base> && make && make install
> Everything works fine and my IOC seems to run cleanly under Windows 7
> but I would feel better if I can run some tests. Are there any tools
> for testing cross builds?
> I want to build my IOC for Linux _and_ Windows but this requires some
> files to be different (e.g. st.cmd). Is there a way to build for both
> platforms from one source directory?
> Best regards
> Martin
> P.S.: I'm still using mingw32 3.4.4.20050522.1-2, mingw32-binutils
> 2.16.91-20050827.1-2 and mingw32-runtime 3.8-1 even with Ubuntu 9.10
> (Karmic) because newer packages in Debian/Ubuntu seem to be broken
> (some important libs for C++ exceptions etc. are missing).
This is the result of a change in the way Mingw 4.x does libstdc++ (not
sure if this is Debian or upstream) and the way EPICS builds (-D_DLL).
The issue is that setting -D_DLL causes all the system headers to expect
to link against a DLL.  For some reason some (all?) symbols associated
with libstd++ are only available in a static library.
A simple workaround is to statically link everything.  Another way is to
statically link the system libraries only.  I'm don't think this is the
best solution, but it is as far as I got.  See the attached patch.
I did this work last spring and haven't looked at it since.  I may not
be remembering everything, but at the time it seemed to be working.  I
could run the unit tests and softIoc under Wine.  I tried again today
and running softIoc fails.  I think this is a Wine issue though.  It
seems to be failing when system() gets called with a NULL pointer.
Michael Davidsaver
NSLSII Controls Group
Brookhaven National Lab
Attachment: 0001-fix-mingw32-cross-build-dll-usage.patch
Description: 0001-fix-mingw32-cross-build-dll-usage.patch
cross compiling base on linux for win32 Martin Konrad
Prev: StreamDevice and IRQs Benjamin Franksen
Next: epics build with cmake Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: cross compiling base on linux for win32 Martin Konrad
Next: StreamDevice and IRQs Benjamin Franksen
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
