For a small and short-lived test setup my A-B ControlLogix PLC needs to read some EPICS values from another system. What are my options? How about using an Ethernet/IP server library? I.e. write a program that uses EZCA to poll the EPICS values periodically, then serve them to the PLC via Ethernet/IP...does this work? I prefer not to have to purchase anything (e.g KEPserver software), and just want to use freeware to get past this test. Any suggestions? Thanks, -- Sincerely, Elliott ================================================================================ Those raised in a morally relative or neutral environment will hold no truths to be self-evident. Elliott Wolin Staff Physicist, Jefferson Lab 12000 Jefferson Ave Suite 8 MS 12A1 Newport News, VA 23606 757-269-7365 ================================================================================
ANJ, 02 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
