1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: ChannelArchiver on Solaris?
To: Ralph Lange <[email protected]>
Cc: Igor Nichvolodin <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 05 Mar 2010 21:15:07 +0100
Hi Ralph,
we can give you the details for sure.
Igor will contact you on Monday.
The main reason for running the archiver on Solaris is the fact that there's no better way to run a cluster then on Solaris.
The archiver is a key component for our control system. So we run the archiver on the cluster. It runs on the active node and there are scripts which start/ stop the archivers in case of a cluster failover. -> not as a cluster resource!
Furthermore we are archiving into a RAID-5 array which itself is host based mirrored to a second RAID.
This works fine with Sun equipment.
I would be harder for sure to get the same kind of reliability on a Linux system
(expecting comments from our Linux gurus...)
Cheers
Matthias
Ralph Lange wrote:
Hello Matthias,
I heard from others they had to give up running the ChannelArchiver2 on Solaris, because getting the required libraries and tools running on Solaris was close to impossible, and just getting a Linux box to run the archiver on was a lot easier and less expensive.
So - if yours works fine, it would be great to have the set of version numbers for the required parts ... :-)
Thanks a *lot*,
Ralph
On Fri 05 Mar 2010 14:23:44 Matthias Clausen wrote:
Hi Ralph,
yes we're running the channel archiver on our Solaris cluster.
Do you have any specific question?
Otherwise: It works fine for us ;-)) (this might not be the information you're looking for...)
-Matthias
Ralph Lange wrote:
Is anybody using the ChannelArchiver on Solaris? Can you share your experiences?
Thanks a lot,
Ralph
Matthias Clausen                         Cryogenic Controls Group(MKS-2)
phone:  +49-40-8998-3256                Deutsches Elektronen Synchrotron
fax:    +49-40-8994-3256                                    Notkestr. 85
e-mail: [email protected]                           22607 Hamburg
WWW-MKS2.desy.de                                                 Germany
ChannelArchiver on Solaris? Ralph Lange
Re: ChannelArchiver on Solaris? Matthias Clausen
Re: ChannelArchiver on Solaris? Ralph Lange
Prev: Re: 2 MAXv problems Ron Sluiter
Next: Re: 2 MAXv problems Jens . Eden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: ChannelArchiver on Solaris? Ralph Lange
Next: Re: ChannelArchiver on Solaris? Matthias Clausen
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
