Subject: |
Re: Building StreamDevice 2-4 / SynApps / Win32 |
"J. Lewis Muir" <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Fri, 12 Mar 2010 09:52:15 -0600 |
On 3/12/10 9:39 AM, J. Lewis Muir wrote:
>>> On 3/11/10 10:55 PM, Mark Rivers wrote:
>>>> I don't think shell is important on Windows, you can build EPICS in a
>>>> Cygwin bash shell or a Windows cmd shell without having to worry about
>>>> it.
>>> Hi, Mark.
>>> Note I'm not talking about the shell from which the make command is
>>> executed; I'm talking about the shell that make uses to execute commands
>>> for a given target.
>>> Lewis
>> Lewis, Mark, All,
>> It seems to me that an easy thing would be to write a Perl script that
>> replicates this code (which is just generating a test file):
>> # create stream.dbd from all RECORDS
>> $(COMMON_DIR)/$(LIBRARY_DEFAULT).dbd: ../CONFIG_STREAM
>> @for r in $(RECORDS); \
>> do echo "device($$r,INST_IO,dev$${r}Stream,\"stream\")"; \
>> done > $@
>> @echo "driver(stream)" >> $@
>> @echo "variable(streamDebug, int)" >> $@
>> @echo "registrar(streamRegistrar)" >> $@
>> endif
>> I can do that but am not sure about how to invoke the Perl script and
>> pass from $(RECORDS) to the Perl script.
>> It would be nice to not have this one part of EPICS dependent on cygwin
>> when the rest it not.
> Hi, John.
> That would work, but I'm not convinced this one part is dependent on
> Cygwin. I still think the problem is just that the target commands are
> getting passed to either the wrong shell or a broken shell.
Hi, John.
Could you try setting the SHELL make variable when you run make?
1. Find where your sh binary is (this example is from a Bourne shell):
$ which sh
/bin/sh
2. Run make with the SHELL variable set to the location of the sh
binary:
$ make SHELL=/bin/sh
Lewis
- Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
- RE: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
- Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
<2010>
2025
Re: Building StreamDevice 2-4 / SynApps / Win32 Andrew Johnson
Re: Building StreamDevice 2-4 / SynApps / Win32 Dirk Zimoch
<2010>
2025
