1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gateways and IOC UAG security: does username to relayed with request?
To: Carl Schumann <[email protected]>
Cc: [email protected]
Date: Wed, 24 Mar 2010 11:50:58 -0500
Hi Carl,
I do this kind of thing extensively and quite routinely.
The user name making the request to the GW does not get passed through to the
other subnet. Instead the user that started the PV gateway process I believe is
the one that the IOC sees. I use a second layer of Access Security in the GW to
access PVs in the IOC.
In my gateway.starter file I have included in the command to start the GW
-gid 55 -uid 265 -server & This I believe will start the GW under the given gid
and uid which is what the IOC sees I think .... at least in my case. Then you
need to allow users (UAG) from the requesting subnet write access to the ASG in
the IOC ... at least this is how I do it.
Then in the IOC you must specifically allow write access from the GW uid in your
access security file.
I can send you an example if you would like.
Marty
Carl Schumann wrote:
We have an IOC that only permits writes from a subset of users. The IOC implements this security using UAG security and it works as expected for applications running on the IOC's subnet. Applications that are not on that IOC's subnet must access it through a gateway. These off the subnet applications can not make any settings even for users that are in the permitted subset. This has also been verified using cainfo.
Does the username of the user running the application make it through the gateway to the IOC? Our guess is no, because the gateway permissions are wide-open and writes to other IOC's without UAG security work fine. How should this kind of issue be handled? I know there is a -uid command line option but single uid will be correct for all users.
Carl Schumann
Re: Gateways and IOC UAG security: does username to relayed with request? Ralph Lange
Gateways and IOC UAG security: does username to relayed with request? Carl Schumann
Prev: Gateways and IOC UAG security: does username to relayed with request? Carl Schumann
Next: Re: Gateways and IOC UAG security: does username to relayed with request? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
