1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: [Request of tech-support] Error in compiling EPICS 3.14.8.2 base with dbCommon.h
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 07 May 2010 11:16:25 -0400
The version of your gcc compiler ('gcc --version') would also be of interest.
Ralph
On Fri 07 May 2010 10:40:36 J. Lewis Muir wrote:
On 5/6/10 9:52 PM, Jincheol B. Kim wrote:
While I am trying to compile EPICS base R3.14.8.2, I got the following error.
-----------------[From here]----------------
Installing generated generic include file
/usr/local/epics/R3.14.8.2/base/include/menuSimm.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I..
-I/usr/local/epics/R3.14.8.2/base/include/os/Linux
-I/usr/local/epics/R3.14.8.2/base/include         ../dbLock.c
In file included from ../dbLock.c:62:
/usr/local/epics/R3.14.8.2/base/include/dbCommon.h:45: error: expected
specifier-qualifier-list before âepicsTimeStampâ
make[3]: *** [dbLock.o] error 1
make[3]: Leaving directory `/usr/local/src/base-3.14.8.2/src/db/O.linux-x86'
make[2]: *** [install.linux-x86] error 2
make[2]: Leaving directory `/usr/local/src/base-3.14.8.2/src/db'
make[1]: *** [db.install] error 2
make[1]: Leaving directory `/usr/local/src/base-3.14.8.2/src'
make: *** [src.install] error 2
[root@******* base-3.14.8.2]#
----------------[End of error]-------------------------
I changed just INSTALL_LOCATION to /usr/local/epics/R3.14.8.2/base and
nothing is changed in configuration files. The value of
EPICS_HOST_ARCH is linux-x86 and I am using CentOS 5.4 with kernel
[root@******* base-3.14.8.2]# uname -a
Linux ******************** 2.6.18-164.15.1.el5xen #1 SMP Wed Mar 17
12:53:17 EDT 2010 i686 i686 i386 GNU/Linux
Would you review the error and tell me what I should do to solve it?
Hi, Jincheol.
Could you send the following:
  /usr/local/epics/R3.14.8.2/base/include/epicsTime.h
I'm wondering if the error you're seeing for dbCommon.h is because the
compiler doesn't know about the epicsTimeStamp type yet?
Also, have you considered using EPICS Base 3.14.11 instead?  EPICS Base
3.14.8.2 is quite old.  If you have a reason for using it, OK.  But
otherwise it would be *much better* to use EPICS Base 3.14.11.
Lewis
[Request of tech-support] Error in compiling EPICS 3.14.8.2 base with dbCommon.h Jincheol B. Kim
Re: [Request of tech-support] Error in compiling EPICS 3.14.8.2 base with dbCommon.h J. Lewis Muir
Prev: Re: [Request of tech-support] Error in compiling EPICS 3.14.8.2 base with dbCommon.h J. Lewis Muir
Next: Re: Experimental Sequencer Release Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: [Request of tech-support] Error in compiling EPICS 3.14.8.2 base with dbCommon.h Jincheol B. Kim
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
