1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AutoSaveRestore of the motor position
To: 张招红 <[email protected]>
Cc: [email protected]
Date: Mon, 10 May 2010 09:52:15 -0500
The scenario you describe is the same as if you commanded the motor to
make a long move and lost IOC power during the move. At IOC boot-up,
autosave would restore the motor's position to the last commanded value,
not the actual position.
Ideally, you would have autosave record the actual position (DRBV) and
use it to restore both the actual and the commanded positions (DVAL) at
boot-up. Autosave is not currently capable of doing that and I question if
it needs to. Recording actual, as opposed to commanded positions,
would incur data acquisition like levels of overhead for something that
rarely happens.
Ron
张招红 wrote:
> Hi,everybody,
> In SSRF beamline control we use the autosave module to save the 'DVAL'
> field and restore the value of a motor position when rebooting.
> Recently we encountered a problem.
> Sometimes one of the controllers(MAXv-8000) in a VME crate crashes
> while the IOC(mvme5500) still runs. Because the motor channel is still
> connected, the system looks OK. In this case if changing the ‘DVAL’
> field to drive the motor, the controller doesn’t response and the
> ‘DRBV’ of the motor keeps unchanged. So the saved value 'DVAL' isn't
> no long the motor real position.
> When hard rebooting the VME crate, the 'DRBV' set by the recovered
> 'DVAL' doesn't match the motor real position.
> Are there some problems in our saving and restoring method? How to
> deal with this kind of problem?
> Any suggestion will be greatly appreciated!
> Zhang Zhaohong(张招红)
> No.239 Zhangheng Road
> PuDong District
> Shanghai Institute of Applied Physics CAS
> Shanghai, China
> Tel: +86-21-33933238
答复: AutoSaveRestore of the motor position 张招红
Prev: RE: AutoSaveRestore of the motor position Mark Rivers
Next: Re: [Request of tech-support] Error in compiling EPICS 3.14.8.2 base with dbCommon.h J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: 答复: AutoSaveRestore of the motor position 张招红
Next: 答复: AutoSaveRestore of the motor position 张招红
