1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: No monitor refresh
To: "Hinko Kocevar" <[email protected]>, <[email protected]>
Date: Tue, 11 May 2010 09:55:39 -0500
As Ralph pointed out, you have set SCAN=I/O Intr.  For this to work your
asyn port driver (called ENV in your case) must do callbacks to device
support when it receives a new value.  Does this driver do so?
You can get information about this by typing
asynReport 10 ENV
That should show you what asyn clients (e.g. device support) have
registered for callbacks on which interfaces.
What happens if you change SCAN to "1 second"?
-----Original Message-----
[mailto:[email protected]] On Behalf Of Hinko Kocevar
Sent: Tuesday, May 11, 2010 9:07 AM
To: [email protected]
Subject: Re: No monitor refresh
Hello Ralph,
On 05/11/10 15:21, Ralph Lange wrote:
> Hello Hinko,
> what EPICS versions are you using for client and IOC?
IOC and client use 3.14.10 EPICS base version.
> Can you show a dump (dbpr <name>, 4) of the record that you are
> connecting to?
Sure, here it is:
epics> dbpr LIBERA01:ENV:ENV_AGC_MONITOR 4
ACKS: NO_ALARM      ACKT: YES           ASG:                ASP:
0x00000000
BKPT: 0x00          COSV: NO_ALARM      DESC: AGC           DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DPVT:
0x50c72c00
DSET: 0x7c620840    DTYP: asynInt32     EIST:               EISV:
NO_ALARM
EIVL: 0x0           ELST:               ELSV: NO_ALARM      ELVL: 0x0
EVNT: 0             FFST:               FFSV: NO_ALARM      FFVL: 0x0
FLNK:CONSTANT 0     FRST:               FRSV: NO_ALARM      FRVL: 0x0
FTST:               FTSV: NO_ALARM      FTVL: 0x0           FVST:
FVSV: NO_ALARM      FVVL: 0x0           INP:INST_IO @asyn(ENV, 725, 1.0)
LALM: 1             LCNT: 0             LSET: 0xe8752e00    MASK:
4294967295
MLIS: 0x38d0320060d0320003000000        MLOK: 0x28700b00    MLST: 1
NAME: LIBERA01:ENV:ENV_AGC_MONITOR      NIST:               NISV:
NO_ALARM
NIVL: 0x0           NOBT: 0             NSEV: NO_ALARM      NSTA:
NO_ALARM
ONST: AUTO          ONSV: NO_ALARM      ONVL: 0x1           ORAW: 1
PACT: 0             PHAS: 0             PINI: YES           PPN:
0x00000000
PPNR: 0x00000000    PRIO: LOW           PROC: 0             PUTF: 0
RDES: 0xa8a10300    RPRO: 0             RSET: 0x34b70a40    RVAL: 1
SCAN: I/O Intr      SDEF: 1             SDIS:CONSTANT       SEVR:
NO_ALARM
SHFT: 0             SIML:CONSTANT       SIMM: NO            SIMS:
NO_ALARM
SIOL:CONSTANT       SPVT: 0x388a2f00    STAT: NO_ALARM      SVAL: 0
SVST:               SVSV: NO_ALARM      SVVL: 0x0           SXST:
SXSV: NO_ALARM      SXVL: 0x0           TEST:               TESV:
NO_ALARM
TEVL: 0x0           THST:               THSV: NO_ALARM      THVL: 0x0
TIME: 2010-05-11 11:18:40.100440000     TPRO: 0             TSE: 0
TSEL:CONSTANT       TTST:               TTSV: NO_ALARM      TTVL: 0x0
TVST:               TVSV: NO_ALARM      TVVL: 0x0           TWST:
TWSV: NO_ALARM      TWVL: 0x0           UDF: 0              UNSV:
NO_ALARM
VAL: 1              ZRST: MANUAL        ZRSV: NO_ALARM      ZRVL: 0x0
> What field of that record are you connecting to?
I did no specify any field - so it is VAL, I guess by default.
Thank you!
Hinko
> Regards,
> Ralph
> On Tue 11 May 2010 6:26:48 Hinko Kocevar wrote:
>> Hi all,
>> I'm experiencing some strange behavior when using camonitor against
an
>> EPICS IOC.
>> For some reason a CA_PROTO_EVENT_ADD response from IOC to CA client
does
>> not arrive, or arrives several minutes later after the PV value has
>> changed. Note that first CA_PROTO_EVENT_ADD response is seen always,
>> only latter CA_PROTO_EVENT_ADD responses do not arrive (or arrive
late)?!
>> This behavior is not seen always - sometimes the IOC would promptly
>> respond with CA_PROTO_EVENT_ADD response when needed.
>> I can see the CA_PROTO_ECHO requests/responses fine on the same
>> camonitor channel link, only CA_PROTO_EVENT_ADD response is not seen.
>> Inspecting the IOC I can see that the value did change (on lower
levels)
>> and caput response is also valid - updated with new value.
>> I've ruled out the network problems, since the issue is raised even
when
>> using cross-over cable to communicate with the IOC. Actually even I
>> update the value in the IOC shell, the camonitor is not refreshed!!
>> Has someone experienced something similar?
>> Are there some conditions that need to fulfilled in order for IOC to
>> send a subsequent CA_PROTO_EVENT_ADD response(s)?
>> TIA & HAND,
>> Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review,
retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
Re: No monitor refresh Hinko Kocevar
Re: No monitor refresh Ralph Lange
Prev: Re: No monitor refresh Ralph Lange
Next: Re: No monitor refresh Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: No monitor refresh Mark Rivers
