1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gateway compilation issue in tsHash.h
Cc: "Denise S. Finstrom" <[email protected]>, [email protected]
Date: Wed, 12 May 2010 17:24:16 -0500
Andrew Johnson wrote:
Hi Carl,
On Wednesday 12 May 2010 11:02:59 Carl Schumann wrote:
We are updating to the latest EPICS gateway, but have found compilation
issues in tsHash.h:
../tsHash.h: At global scope:
../tsHash.h:27: error: ISO C++ forbids declaration of 'gphPvt' with no
type
../tsHash.h:27: error: expected ';' before '*' token
Which version of Base are you building this with? You *have* to use R3.14.11 (or later, but we haven't released any since), which you would want anyway since that has essential bug fixes in CAS and I believe even an API change.
- Andrew
We intended to be building with R3.14.11 but in fact were not. Now that we have that corrected it does in deed build. Thanks.
Gateway compilation issue in tsHash.h Carl Schumann
Re: Gateway compilation issue in tsHash.h Andrew Johnson
Prev: Re: Looking for runcontrol record sources Claude Saunders
Next: Re: No monitor refresh Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Gateway compilation issue in tsHash.h Andrew Johnson
Next: Looking for runcontrol record sources emmanuel_mayssat
