On Mittwoch, 19. Mai 2010, Davidsaver, Michael wrote: The usual way, lots of trial, and lots of error :) What about all the other cross-compiler targets and their specific configuration? While I've had many frustrations with it, I must say that this is were the Base build system helped me. Mostly this just worked. Of course I only cross-build RTEMS, not other host targets. There is much less chance of shared library dependency problems when you don't have shared libraries! I mean, how do I configure a debian package for epics base in the first place? Set PATH, LD_LIBRARY_PATH in the environment and patch the build system to avoid linking with -rpath. Among the debian packaging tools is the Lintian utility which analyzes the build package for common mistakes. After ~12 years it knows about a lot of problems. Will there be some /etc/epics.conf? That is on hold until Andrew and I come to an agreement on how this should be implemented. Until then the EPICS_* environment variables are it. OTOH, doesn't EPICS At present it actually doesn't. These are runtime parameters related to channel access and IOCs. Thankfully neither are needed during the build. Michael
ANJ, 02 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
