1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Recovering invalid records
To: EPICS tech-talk <[email protected]>
Date: Wed, 26 May 2010 12:03:09 -0700
Hello,
I have mbbi records which are using stream/asyn.
For some reason my records become invalid after some time.
SCAN is passive and triggered through FLNK of the associated mbbo record.
Is there a way to recover from an invalid record?
What turns it into invalid in the first place?
(Well, I could do some testing to answer that latter question...)
Thank you in advance,
Emmanuel
<pre>
cls1ir:6190>dbpr DMC2183:3:FHSyncModeMI
ASG:                DESC:               DISA: 0             DISP: 0
DISV: 1             NAME: DMC2183:3:FHSyncModeMI            RVAL: 0
SEVR: INVALID       STAT: NO_ALARM      SVAL: 0             TPRO: 0
VAL: 0
cls1ir:6190>dbpr DMC2183:3:FHSyncModeMI 3
ACKS: INVALID       ACKT: YES           ASG:                BKPT: 00
COSV: NO_ALARM      DESC:               DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DTYP: DMC2183_devMbbiAsyncStream
EIST:               EISV: NO_ALARM      EIVL: 0x0           ELST:
ELSV: NO_ALARM      ELVL: 0x0           EVNT: 0             FFST:
FFSV: NO_ALARM      FFVL: 0x0           FLNK:CONSTANT 0     FRST:
FRSV: NO_ALARM      FRVL: 0x0           FTST:               FTSV: NO_ALARM
FTVL: 0x0           FVST:               FVSV: NO_ALARM      FVVL: 0x0
INP:INST_IO @dmc2183.stream getHardwareSyncMode(DMC2183:3,F) DMC2183:3
LALM: 0             LCNT: 163           MASK: 0             MLST: 0
NAME: DMC2183:3:FHSyncModeMI            NIST:               NISV: NO_ALARM
NIVL: 0x0           NOBT: 0             NSEV: NO_ALARM      NSTA: NO_ALARM
ONST: Rel           ONSV: NO_ALARM      ONVL: 0x0           ORAW: 0
PACT: 1             PHAS: 0             PINI: NO            PRIO: LOW
PROC: 1             PUTF: 0             RPRO: 1             RVAL: 0
SCAN: Passive       SDEF: 1             SDIS:CONSTANT       SEVR: INVALID
SHFT: 0             SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM
SIOL:CONSTANT       STAT: NO_ALARM      SVAL: 0             SVST:
SVSV: NO_ALARM      SVVL: 0x0           SXST:               SXSV: NO_ALARM
SXVL: 0x0           TEST:               TESV: NO_ALARM      TEVL: 0x0
THST:               THSV: NO_ALARM      THVL: 0x0
TIME: 2010-05-26 11:39:56.102969366     TPRO: 0             TSE: 0
TSEL:CONSTANT       TTST:               TTSV: NO_ALARM      TTVL: 0x0
TVST:               TVSV: NO_ALARM      TVVL: 0x0           TWST: Abs
TWSV: NO_ALARM      TWVL: 0x0           UDF: 0              UNSV: NO_ALARM
VAL: 0              ZRST: ---           ZRSV: NO_ALARM      ZRVL: 0x0
</pre>
Emmanuel
Re: Recovering invalid records Ned Arnold
Prev: Re: CA web service Re: iPhone port Matthias Clausen
Next: labCa 64-bit emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: stream device formatting question Burkhard Kolb
Next: Re: Recovering invalid records Ned Arnold
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
