On Wednesday 26 May 2010 09:33:33 fenggangbian wrote:
> Hi,
> Now I am working a program using LabView talk to EPICS by shared
> memeory. LabView create a local softIOC ,firstly LabView talk to the soft
> ioc and use the softioc to connect other outside ioc. I may already use
> LabView to connect soft IOC. I encounter a question that how to write a
> waveform PV in soft IOC to other waveform PV in anther IOC. The support
> record of array in the soft IOC only have subArray record and waveform
> record. Such as aao etc record don't support.
The waveform record has soft support using the INP link, so your second IOC
could read the waveform data from the soft IOC. If you mark the input link as
CP it will process that record automatically whenever the source record posts
a monitor on value update.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- RE: a waveform record question Mark Rivers
- a waveform record question fenggangbian
Epics 3.14.8: faulty registrar statement in dbd causes memPartAlloc error on vxWorks Goetz Pfeiffer
Re: Epics 3.14.8: faulty registrar statement in dbd causes memPartAlloc error on vxWorks Andrew Johnson
<2010>
<2010>
