1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES
To: Matt Newville <[email protected]>
Date: Fri, 28 May 2010 10:21:30 -0400
Hi Matt,
as Andrew covered the technical aspects and pointed out solutions, I just want to clarify:
In your original mail, you sounded as you were assuming that the environment variable EPICS_CA_MAX_ARRAY_BYTES was introduced with the intention of limiting the size of arrays that CA is able to handle.
My statement was: No, it was the other way round. The limitation had been there from the beginning. The environment variable was introduced with the intention to overcome this limitation and allow CA to handle larger arrays.
Sorry for being not clear enough in the first place.
Cheers,
Ralph
On Thu 27 May 2010 21:25:01 Matt Newville wrote:
Hi Ralph,
Thanks for the reply.
On Wed, May 26, 2010 at 11:27 AM, Ralph Lange <[email protected]> wrote:
Hi Matt,
nope, it's the other way round:
Maybe I'm still not understanding completely because I don't see much difference between your explanation and what I said,
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Till Straumann
labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES emmanuel_mayssat
RE: labCA and EPICS_CA_MAX_ARRAY_BYTES Mark Rivers
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Matt Newville
Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Ralph Lange
Prev: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Andrew Johnson
Next: Fall Epics Meeting location? Jane Richards
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: labCA and EPICS_CA_MAX_ARRAY_BYTES Till Straumann
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
