[email protected] wrote:
Through exec() calls a state machine can call any program or script
written in any language on your system. You find that too low level?!
Could you explain your definition of high level in that context?
end_stations_protocol:
align sample with beam
detector_acquire_image
move_grid
rotate_sample
each command is drag-and-dropped by the experimenter (not a programmer)
sequence can be changed by the experimenter function of what he wants to do
He should be able to work independently of programmers
Of course, each of those states can be further broken down and later refined
(I can easily see a state machine with 500+ states)
interpreted languages are better, no compilation needed
+ you can program a sequence on the fly (no downtime required)
Ahh... now I can see what you are trying to achieve.
These are not the usual finite state machines, though, and the pluggable
parts are not states (as the term is used in EPICS context).
The sequencer is not the right tool to do this, neither probably are the
FSM record or the Qt4 thing you were mentioning.
You are looking for a generic script execution engine for an interpreted
language, with (possibly) a graphical interface. The trickiest part of
these things is getting the exception/error handling right, with the
different options of ignoring vs. instant correcting vs. fallback vs.
safe state transition. To sucessfully do that, state machine like
behavior will be part of the solution, of course.
The closest thing within the EPICS context (that I know of) is the PEM
system you mentioned [1], used at the APS for their scripted operation
procedures. It almost looks like what you described in your last mail -
I don't know implementation details or recent developments, though.
Other places to look would be the high level app frameworks: XAL and GDA
might have interfaces that allow such kind of hierarchical script
snippeting. Again: I would see the error handling always being the
hard-to-get-right and crucial part of these engines.
Good luck!
Ralph
[1]
http://www.aps.anl.gov/Accelerator_Systems_Division/Operations_Analysis/manuals/APSPEM/APSPEM4.html
- Re: state machine programming Claude Saunders
- RE: state machine programming Dalesio, Leo
- state machine programming emmanuel_mayssat
- Re: state machine programming Ben Franksen
- Re: state machine programming emmanuel_mayssat
- Re: state machine programming Ralph Lange
ask for help renliqin
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
