[email protected] wrote:
As a follow up question, what would be the recommended way of performing
calculations on array data within the EPICS database? Do I have to
resort to subRoutine records? In my individual channels of data
(subArray records) I have multiple quartets of data, one for for each
turn captured, I need to perform calculations on each of these quartets
to determine beam position for each turn.
General calculations can be done with the aCalcout record (SynApps). But
as far as I know you cannot do iterations over n-tuples in an array.
Since you have to calculate 2 (mabye 3) values simultaneously out of 4
inputs you are probably served best with the genSub (or aSub if you have
base 3.14.11)
Dirk
- RE: Waveform Record Device Support graham.cox
Re: Waveform Record Device Support Burkhard Kolb
Re: RE: Waveform Record Device Support nda
<2010>
2025
Re: Waveform Record Device Support Till Straumann
<2010>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
