Hi All, I am getting following error when I used burt restore tool, burtwb ERROR: BurtProcessSnapshotFile() string column >ControlName< not in file >/tmp/CLS2010-159-0608-114007.gz100610-122455-30608clsop51< The above command is called like "burtwb -f tmp/CLS2010-159-0608-114007.gz100610-122455-30608clsop51" I am using the latest version of burt, which is 20080801 with Epics Base Version 3.14.11 on Fedora 11 64 bit operating system. I tried the burt version, 20070626 and the behavior is the same. Also, I tested on Fedora Core 8 with 32 bit operating system and there it is working fine, but I need to make it work for Fedora 11 64 bit. Could anyone help me in fixing the issue? Thanks in advance. Best Regards, Ramu
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
