Hi all,
We have a Pfeiffer Turbo Pump, model TSH071E, and wish to communicate with it.
Has anyone developed a device driver and/or stream device protocol files that could be
used, or a similar driver/protocol files that could be used a starting point?
Also I found:
while doing research. Can anyone confirm (or deny) that this is the correct protocol
specification to use?
Regards
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
ANJ, 02 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
