1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: error compiling base for rtems
To: "tech-talk" <[email protected]>
Date: Mon, 28 Jun 2010 10:56:09 +0800
hi,
when I tried to compile the base3.14.10 for latest RTEMS version, it shows the following errors:
make[3]: Entering directory `/usr/local/epics/r3.14.10/base-3.14.10/src/libCom/O.RTEMS-pc386'
/opt/rtems/bin/i386-rtems-g++ -B/opt/rtems/i386-rtems/pc386/lib/ -specs bsp_specs -qrtems   -c   -mtune=i386               -DUNIX      -O2 -g -g  -Wall         -DOMIT_NFS_SUPPORT  -I. -I../O.Common -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/RTEMS -I../../../include         ../../../src/l!
 ibCom/osi/os/RTEMS/osdTime.cpp
../../../src/libCom/osi/os/RTEMS/osdTime.cpp: In function 'void osdNTPInit()':
../../../src/libCom/osi/os/RTEMS/osdTime.cpp:61: error: 'close' was not declared in this scope
../../../src/libCom/osi/os/RTEMS/osdTime.cpp: At global scope:
../../../src/libCom/osi/os/RTEMS/osdTime.cpp:132: warning: 'done' defined but not used
make[3]: *** [osdTime.o] Error 1
make[3]: Leaving directory `/usr/local/epics/r3.14.10/base-3.14.10/src/libCom/O.RTEMS-pc386'
make[2]: *** [install.RTEMS-pc386] Error 2
make[2]: Leaving directory `/usr/local/epics/r3.14.10/base-3.14.10/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/usr/local/epics/r3.14.10/base-3.14.10/src'
make: *** [src.install] Error 2
can anyone give some hints? thanks a lot for your help.
Best regards
Geyang  2010-06-28
Re: error compiling base for rtems Eric Norum
Prev: Re: Re: error building latest rtems Silver
Next: Re: error compiling base for rtems Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
