1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: streamDev - ENUM Converter (%{string0|string1|...})
To: <[email protected]>, <[email protected]>
Date: Fri, 23 Jul 2010 17:57:01 +0100
Should cc = "thr low" rather than "thr low valid"?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Dr. Peter Zumbruch
Sent: 23 July 2010 16:09
To: [email protected]
Subject: streamDev - ENUM Converter (%{string0|string1|...})
Hi all,
I have problems reading the output from my serial device using streamDev
my protocol is
> thr_low_valid_intr {
>     Terminator  = LF;
>     cc="thr_low_valid";
>     in $recvKey $cc" %*x %{INVALID|VALID}";
my record is:
> record(bi, "etrax201:RLTH:thr_low_valid") {
>   field(DESC, "thr low valid")
>   field(SCAN, "I/O Intr")
>   field(DTYP, "stream")
>   field(INP, "@hadcon_RLTH.proto thr_low_valid_intr()
> $(device,undefined)")
>   field(VAL, "0")
>   field(ZSV, "MINOR")
>   field(ZNAM, "INVALID")
>   field(ONAM, "VALID")
"device" set in st.cmd
but the result (var streamDebug 1) is that VALID or INVALID is not
recognized:
> 2010/07/23 16:52:35.449 hadcon AsynDriverInterface.cc:983:
> AsynDriverInterface::asynReadHandler(etrax201:RLTH:thr_low_valid,
> buffer="RECV RLTH thr_low 0x40 VALID<0a>", received=29 eomReason=NONE)
> ioAction=AsyncRead
> 2010/07/23 16:52:35.451 hadcon StreamCore.cc:910:
> StreamCore::readCallback(etrax201:RLTH:thr_low_valid,
> status=StreamIoSuccess input="RECV RLTH thr_low 0x40 VALID<0a>", size=29)
> 2010/07/23 16:52:35.452 hadcon StreamCore.cc:967:
> StreamCore::readCallback(etrax201:RLTH:thr_low_valid)
> inputBuffer="RECV RLTH thr_low 0x40 VALID<0a>", size 29
> 2010/07/23 16:52:35.454 hadcon StreamCore.cc:989:
> StreamCore::readCallback(etrax201:RLTH:thr_low_valid) inTerminator
> <0a> at position 28
> 2010/07/23 16:52:35.456 hadcon StreamCore.cc:1056:
> StreamCore::readCallback(etrax201:RLTH:thr_low_valid) input line:
> "RECV RLTH thr_low 0x40 VALID"
> 2010/07/23 16:52:35.457 hadcon StreamCore.cc:1076:
> StreamCore::readCallback(etrax201:RLTH:thr_low_valid) async match
> failure: just restart
> 2010/07/23 16:52:35.459 hadcon AsynDriverInterface.cc:674:
> AsynDriverInterface::readRequest(etrax201:RLTH:thr_low_valid, 4000
> msec reply, 500 msec read, expect 0 bytes, asyn=yes)
> 2010/07/23 16:52:35.464 hadcon AsynDriverInterface.cc:1067:
> AsynDriverInterface::asynReadHandler(etrax201:RLTH:thr_low_valid)
> readMore=0, ioAction=AsyncRead
The rest of the protocol is working just this function not, why?
Any suggestions appreciated,
best regards,
Peter
 Dr. rer. nat. Peter W. Zumbruch
 EE - department / Controls group / GSI
 E-Mail: P.Zumbruch_at_gsi.de
 Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
 GSI Helmholtzzentrum für Schwerionenforschung GmbH
 Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
 Gesellschaft mit beschränkter Haftung
 Sitz der Gesellschaft: Darmstadt
 Handelsregister: Amtsgericht Darmstadt, HRB 1528
 Geschäftsführung: Professor Dr. Dr. h.c. Horst Stöcker,
 Christiane Neumann, Dr. Hartmut Eickhoff
 Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
 Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Scanned by iCritical.
streamDev - ENUM Converter (%{string0|string1|...}) Dr. Peter Zumbruch
Prev: Re: copying output of Linux ioc to file Ralph Lange
Next: Anyone using Siemens WinCC SCADA? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: streamDev - ENUM Converter (%{string0|string1|...}) Dr. Peter Zumbruch
