1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: HTML Device Driver
To: EPICS <[email protected]>
Date: Wed, 28 Jul 2010 10:58:43 -0500
Title: HTML Device Driver
That is a good item of general interest.  Probably would need something that cleans up HTML source so that common XML code could be used for reading either HTML or XML sources.  Any of several XML libraries could be used: libxml, lxml, or mxml.
Describing the XML "device" for the INP field, and how that maps to an XML node such as through XPATH, might be an interesting challenge.
Will there be a codeathon with the upcoming EPICS meeting?  This is a candidate.
Pete
On 7/28/10 10:33 AM, David Dudley wrote:
Here’s a new one for you (Got Ralph and Michael going about how to do it, anyway ;-)
Almost all of the PLC equipment we’re going to be using on NSLS/2 is connected on Ethernet.
It is common practice in the communications modules now, to integrate an embedded WEB server into the device.  Both the Siemens and Rockwell hardware we’re going to use have that capability, as well as most of the new generation of instrumentation.
Does anyone have knowledge of an EPICS device driver that is capable of reading and interpreting a WEB page or XML page?  Seems that this would be the most universal way to read data from all this differing equipment, if such a driver was available.
David Dudley
Pete
HTML Device Driver David Dudley
Prev: HTML Device Driver David Dudley
Next: Re: HTML Device Driver J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
