1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: HTML Device Driver
To: David Dudley <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 28 Jul 2010 11:17:12 -0700
David,
I use stream to do just that.
PCRE (support for regular expression) needs to be compiled in to grab values between tags. (i.e. <epics_val1>45.6</epics> somewhere on the webpage)
Your webpages may be complicated (all in one, java, flash, etc), but if you control the webserver, you can create simple webpages to interface specifically with your epics driver.
Good luck,
Emmanuel
On 11:33 Wed 28 Jul     , David Dudley wrote:
> Here¹s a new one for you (Got Ralph and Michael going about how to do it,
> anyway ;-)
> Almost all of the PLC equipment we¹re going to be using on NSLS/2 is
> connected on Ethernet.
> It is common practice in the communications modules now, to integrate an
> embedded WEB server into the device.  Both the Siemens and Rockwell hardware
> we¹re going to use have that capability, as well as most of the new
> generation of instrumentation.
> Does anyone have knowledge of an EPICS device driver that is capable of
> reading and interpreting a WEB page or XML page?  Seems that this would be
> the most universal way to read data from all this differing equipment, if
> such a driver was available.
> David Dudley
Emmanuel
HTML Device Driver David Dudley
Prev: Re: Tech-talk archives excluded from indexing? Ned Arnold
Next: Re: Tech-talk archives excluded from indexing? John Hammonds
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: HTML Device Driver Rod Nussbaumer
Next: Support for vxWorks 6.6 through 6.8 Andrew Johnson
