1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Analog output device support design
To: Ralph Lange <[email protected]>
Cc: [email protected]
Date: Thu, 29 Jul 2010 09:38:03 +1000
Hi Ralph & Andreas,
Sorry, I've been a bit too quiet on this thread.
On Wed, 2010-07-28 at 09:51 -0400, Ralph Lange wrote:
> Here I would like to ask Angus, if the two-step conversion is really needed.
> While in some cases (Andreas was giving examples) the two-step
> conversion might be useful and appropriate, it is *not* the regular case.
> Usually the database designer sets LINR, EGU, EGUF, and EGUL. They will
> do that for every analog record that does linear conversion, so I would
> not consider this an extra burden.
What I initially did for the DAC is implementing an @param which set
EGUF & EGUL by default if they weren't already set. This is what I
described in my original post, when I didn't quite know what I was
doing.
Then I looked at the results and realised having "@5V BIP" is totally
redundant given the EGUF/EGUL, as you guys have both kindly explained to
me above. So I pulled all that code out - device support is now much
slimmer and simpler, and more standard.
In case I haven't explained well enough, here's a simple test database
record for my new device support:
record(ao, "analog1")
		  field(DESC, "Analog out channel 0")
		  field(DTYP, "msda128")
		  field(OUT, "#C2 S0")
		  field(LINR,"LINEAR")
		  field(EGUF, 10)
		  field(EGUL, -10)
... for a channel jumpered +/- 10v bipolar. Nice and simple.
I'll post the device support sources & drivers somewhere publicly as
well, once they're done (just need to check with the uni first.)
Angus
Re: Analog output device support design Luedeke Andreas
Re: Analog output device support design Ralph Lange
Prev: Re: Tech-talk archives excluded from indexing? Maren Purves
Next: Re: Tech-talk archives excluded from indexing? Angus Gratton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Analog output device support design Ralph Lange
Next: Maven2 repository for EPICS Carcassi, Gabriele
