1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: monitoring a very large number of channels
To: "Patrick Thomas" <[email protected]>, <[email protected]>
Date: Fri, 30 Jul 2010 08:54:32 -0400
Title: RE: monitoring a very large number of channels
In both cases - what is your network configuration? That is one possible limitation
-- each channel access monitor uses 28 bytes (as I recall).
-- each  tcp/ip packet has 64 bytes of overhead.
-- channel access buffers and optimizes packets between a server and a client to limit the impact of the tcp/ip overhead.
-- Jeff has performance numbers and test code so that you can run the tests on your hardware.
What archiver are you using? The channel archiver with the RTree index has been  benchmarked to archive 10K channels per second on standard PC hardware. With some high end disks, you could improve this.
-----Original Message-----
From: [email protected] on behalf of Patrick Thomas
Sent: Fri 7/30/2010 5:51 AM
To: [email protected]
Subject: monitoring a very large number of channels
I was wondering what the limiting factor is with regards to placing
monitors on a large number of channels. For example, how many channels
can camonitor or channel archiver watch?
Thank you,
Patrick
monitoring a very large number of channels Patrick Thomas
Prev: sample gas analysis peter.leicester
Next: Re: monitoring a very large number of channels Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: monitoring a very large number of channels Patrick Thomas
