1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caPutLog Performance
To: Gary Carr <[email protected]>
Cc: TechTalk <[email protected]>
Date: Thu, 05 Aug 2010 08:37:47 +0200
Hi Gary.
Gary Carr wrote:
Does anyone have any performance data for caPutLogging? How does it effect the IOC? How many logs can you do per second?
Gongfa Liu ran several tests while he was working at DESY.
I do not recall any statistical performance numbers he took.
Maybe he can comment on this.
In any case there's a built in queue which performs like a throttle.
I would be interested in any data for the old system (3.13.4), and the new 3.14 caPutLogger.
There are several improvements in 3.14 which will not affect the CPU load but rather the correct behavior when you keep track of put to the same channel within a given time (keeping track of the min, max values when e.g. writing to a channel with a slider). These changes still need to be retrofitted into the current release.
The CPU load was never an issue and so we did neither measure nor change anything in this respect.
Beware: If you are writing regularly from a program outside the IOC through channel access to the IOC - this will trigger caPutLogging :-(
In our case we are forwarding puLog, snlLog, sysLog, alarms ... through logMessage processes to our JMS based logging system.
Cheers
Matthias
Matthias Clausen                         Cryogenic Controls Group(MKS-2)
phone:  +49-40-8998-3256                Deutsches Elektronen Synchrotron
fax:    +49-40-8994-3256                                    Notkestr. 85
e-mail: [email protected]                           22607 Hamburg
WWW-MKS2.desy.de                                                 Germany
caPutLog Performance Gary Carr
Prev: caPutLog Performance Gary Carr
Next: CSS/BOY macro substitution problem PaweÅ PrÄdki
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
