1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS/BOY macro substitution problem
To: Paweł Prędki <[email protected]>, TechTalk <[email protected]>
Date: Thu, 05 Aug 2010 09:43:00 -0400
Hi Pawel,
>I've started using the CSS ennvironment and BOY for creating GUIs but
>I've come across a problem with macro substitution.
Thanks for using BOY and ask the questions!
>I'm creating a GUI for a data acquisition system which consists of
>several DAQ boards. My aim is to have only one XY graph visible at once
>on the screen and be able to switch between them using, for example,
>action buttons.
There may be other options which can make this task easier: using Tab widget or change the pv name of a trace from action button via script.
>However, when I specify the macro value for the whole display I am not able to change
>it using the action buttons. Somehow, the display macro value definition
>trumps the one given by the action button.
The macros property cannot be changed via script during runtime. It is only loaded once during opi startup. The display macros will replace the same one from its parents.
>The only way I was able to make it work was not specifying any display
>macro value. This, however, results in an ugly first screen where all
>the controls are disconnected since the macro is undefined. Clicking one
>of the action buttons connects to the correct card.
Still cannot understand that clearly. Could you send me the opi files?
Xihui
CSS/BOY macro substitution problem PaweÅ PrÄdki
Prev: Problem with streamDevice and I/O Intr Florian Feldbauer
Next: RE: CSS/BOY macro substitution problem Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CSS/BOY macro substitution problem PaweÅ PrÄdki
