1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: FW: Making a case for cases
Date: Thu, 5 Aug 2010 14:06:26 -0400
Title: RE: Making a case for cases
I gots to learn to use "reply all" for these things. -m
Sent: Thursday, August 05, 2010 2:02 PM
To: 'Dalesio, Leo'
Subject: RE: Making a case for cases
>>There was one bad part of the SNS naming. As I recall, the device instance was ambiguous as the cell number and the device instance were collapsed into 3 digits. So cell 3 pump 12 was the same as cell 31 pump 2. I don't know if you inherit this - or if you put the device instance separate.
Bob
Yeah, a highly placed source inside SNS, speaking on condition of anonymity,  had told us about that.
Thanks again, Kay!
Our "instance" is either "instance" or "position along beamline in cm," depending on where in the system we are.  It's a little clunky, but I think it'll serve us well.
In either case, it's separated by "_" from the device name:  cell31pump_002.
Cheers -Mathias
Re: FW: Making a case for cases Ralph Lange
Prev: Re: Making a case for cases Steven M. Hartman
Next: Re: Making a case for cases Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with streamDevice and I/O Intr Florian Feldbauer
Next: Re: FW: Making a case for cases Ralph Lange
