1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Making a case for cases
To: [email protected]
Cc: "Purcell, J. David" <[email protected]>
Date: Thu, 5 Aug 2010 14:42:56 -0500
On Thursday 05 August 2010 14:10:52 Purcell, J. David wrote:
> There are different interpretations that all allow different "valid" names.
>  But lack of enforcement also allowed names to also be flat out wrong.  And
> now those names are imbedded and we have no real plan on how to fix them.
> In the beginning, if we were told to fix the wrong names, there might have
> been an effort to get to one interpretation of the convention.
Note that since R3.14.11 the IOC supports record aliases, which may provide a
path to fixing wrong names (as long as the right names don't clash with other
wrong names).  You would rename the records to the right names and add aliases
for the wrong names that are in use, which allows you to take as long as you
like to fix all the clients that are still using the wrong names; finally you
delete the aliases when they are no longer needed.  If you do have name
clashes you can probably still do it, but it might take a few cycles.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: Making a case for cases Steiner, Mathias
Re: Making a case for cases Alan Biocca
medm Mezger Anton-Chr.
Re: Making a case for cases Steven M. Hartman
Re: Making a case for cases Purcell, J. David
Prev: Theweb site for the EPICS October meeting is now open. http://www.bnl.gov/epics/ Dalesio, Leo
Next: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Making a case for cases Purcell, J. David
Next: RE: Making a case for cases Steiner, Mathias
