1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.?
To: [email protected]
Date: Thu, 5 Aug 2010 16:45:10 -0500
Hi David,
On Thursday 05 August 2010 16:12:40 David Dudley wrote:
> Where I was having the problem, was in building the 'extensions' directory.
> A number of them appear to believe that the include files are at
> '../include', along with the 'configure' and 'bin' directories.
It sounds like you need to edit your extensions/configure/RELEASE file and
point EPICS_BASE to where your INSTALL_LOCATION was set for the Base build.
It defaults to assuming that base is at ../base but you can change that.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? David Dudley
Prev: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Andrew Johnson
Next: RE: Making a case for cases Steiner, Mathias
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? David Dudley
Next: VxWorks and Radius Authentication Gary Carr
