1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: BOY - XY Graph and macro substitution
To: TechTalk <[email protected]>
Date: Fri, 06 Aug 2010 14:00:20 +0200
Hello,
I've come across another problem with BOY. This time it concerns the XY Graph widget.
It seems this widget does not substitute macros. The attached file demonstrates this behavior. A Text Update, a Label and an XY Graph widgets are included. For the first two, the $(amacro) text is substituted but this does not happen for text fields in the XY Graph, namely the Title and Axis Titles.
Is it a desired behavior or is it a bug?
Cheers,
Pawel Predki
<?xml version="1.0" encoding="UTF-8"?>
<display typeId="org.csstudio.opibuilder.Display" version="1.0">
  <widget_type>Display</widget_type>
  <macros>
    <include_parent_macros>true</include_parent_macros>
    <amacro>MACROTEST</amacro>
  </macros>
  <width>800</width>
  <rules />
  <scripts />
  <show_ruler>true</show_ruler>
  <height>600</height>
  <show_edit_range>true</show_edit_range>
  <name>Display</name>
  <grid_space>6</grid_space>
  <snap_to_geometry>true</snap_to_geometry>
  <show_grid>true</show_grid>
  <y>-1</y>
  <actions hook="false" />
  <foreground_color>
    <color red="192" green="192" blue="192" />
  </foreground_color>
  <background_color>
    <color red="240" green="240" blue="240" />
  </background_color>
  <x>-1</x>
  <widget typeId="org.csstudio.opibuilder.widgets.xyGraph" version="1.0">
    <trace_0_trace_color>
      <color red="21" green="21" blue="196" />
    </trace_0_trace_color>
    <axis_0_auto_scale>true</axis_0_auto_scale>
    <axis_1_time_format>0</axis_1_time_format>
    <trace_0_plot_mode>0</trace_0_plot_mode>
    <trace_count>1</trace_count>
    <trace_0_chronological>true</trace_0_chronological>
    <axis_0_show_grid>true</axis_0_show_grid>
    <axis_0_log_scale>false</axis_0_log_scale>
    <trace_0_point_size>4</trace_0_point_size>
    <show_legend>false</show_legend>
    <y>24</y>
    <x>30</x>
    <visible>true</visible>
    <axis_1_visible>true</axis_1_visible>
    <height>313</height>
    <axis_1_maximum>100.0</axis_1_maximum>
    <axis_1_title_font>
      <fontdata fontName="Arial" height="9" style="1" />
    </axis_1_title_font>
    <border_width>1</border_width>
    <axis_0_axis_color>
      <color red="0" green="0" blue="0" />
    </axis_0_axis_color>
    <name>XY Graph</name>
    <axis_1_auto_scale_threshold>0.0</axis_1_auto_scale_threshold>
    <trace_0_line_width>1</trace_0_line_width>
    <show_toolbar>false</show_toolbar>
    <axis_1_show_grid>true</axis_1_show_grid>
    <axis_0_grid_color>
      <color red="200" green="200" blue="200" />
    </axis_0_grid_color>
    <axis_0_auto_scale_threshold>0.0</axis_0_auto_scale_threshold>
    <trace_0_name>$(trace_0_y_pv)</trace_0_name>
    <trace_0_update_mode>0</trace_0_update_mode>
    <axis_0_axis_title>X Axis $(amacro)</axis_0_axis_title>
    <axis_1_axis_color>
    </axis_1_axis_color>
    <foreground_color>
      <color red="0" green="0" blue="255" />
    </foreground_color>
    <backcolor_alarm_sensitive>false</backcolor_alarm_sensitive>
    <axis_1_axis_title>Y Axis $(amacro)</axis_1_axis_title>
    <axis_0_maximum>100.0</axis_0_maximum>
    <axis_0_time_format>0</axis_0_time_format>
    <axis_1_log_scale>false</axis_1_log_scale>
    <title_font>
      <fontdata fontName="Arial" height="12" style="1" />
    </title_font>
    <axis_1_dash_grid_line>true</axis_1_dash_grid_line>
    <axis_0_visible>true</axis_0_visible>
    <forecolor_alarm_sensitive>false</forecolor_alarm_sensitive>
    <trace_0_x_pv />
    <trace_0_y_pv>$(pv_name)</trace_0_y_pv>
    <axis_0_title_font>
    </axis_0_title_font>
    <axis_1_auto_scale>true</axis_1_auto_scale>
    <trace_0_concatenate_data>true</trace_0_concatenate_data>
    <show_plot_area_border>false</show_plot_area_border>
    <widget_type>XY Graph</widget_type>
    <enabled>true</enabled>
    <width>331</width>
    <trace_0_buffer_size>100</trace_0_buffer_size>
    <trigger_pv />
    <axis_count>2</axis_count>
    <transparent>false</transparent>
    <axis_0_dash_grid_line>true</axis_0_dash_grid_line>
    <trace_0_x_axis_index>0</trace_0_x_axis_index>
    <trace_0_point_style>0</trace_0_point_style>
    <tooltip>$(trace_0_y_pv)
$(trace_0_y_pv_value)</tooltip>
    <border_alarm_sensitive>true</border_alarm_sensitive>
    <trace_0_y_axis_index>1</trace_0_y_axis_index>
    <border_style>0</border_style>
    <plot_area_background_color>
      <color red="255" green="255" blue="255" />
    </plot_area_background_color>
    <title>Macro text: $(amacro)</title>
    <pv_name />
    <axis_1_minimum>0.0</axis_1_minimum>
    <axis_0_minimum>0.0</axis_0_minimum>
    <border_color>
      <color red="0" green="128" blue="255" />
    </border_color>
    <scripts />
    <trace_0_anti_alias>true</trace_0_anti_alias>
    <background_color>
    </background_color>
    <rules />
    <trace_0_trace_type>0</trace_0_trace_type>
    <axis_1_grid_color>
    </axis_1_grid_color>
    <trace_0_update_delay>100</trace_0_update_delay>
  </widget>
  <widget typeId="org.csstudio.opibuilder.widgets.TextUpdate" version="1.0">
    <vertical_alignment>1</vertical_alignment>
    <show_units>true</show_units>
    <auto_size>false</auto_size>
    <scripts />
    <height>43</height>
    <name>Text Update</name>
    <format_type>0</format_type>
    <precision_from_pv>true</precision_from_pv>
    <pv_name />
    <background_color>
    </background_color>
    <foreground_color>
    </foreground_color>
    <widget_type>Text Update</widget_type>
    <text>Text Update -&gt; Macro text: $(amacro)</text>
    <precision>0</precision>
    <font>
      <fontdata fontName="Arial" height="9" style="0" />
    </font>
    <width>265</width>
    <rules />
    <border_color>
    </border_color>
    <horizontal_alignment>1</horizontal_alignment>
    <y>138</y>
    <tooltip>$(pv_name)
$(pv_value)</tooltip>
    <x>414</x>
  </widget>
  <widget typeId="org.csstudio.opibuilder.widgets.Label" version="1.0">
    <widget_type>Label</widget_type>
    <text>Label -&gt; Macro text: $(amacro)</text>
    <font>
    </font>
    <width>265</width>
    <rules />
    <scripts />
    <height>49</height>
    <name>Label</name>
    <border_color>
    </border_color>
    <y>192</y>
    <tooltip />
    <x>414</x>
    <background_color>
    </background_color>
    <foreground_color>
    </foreground_color>
  </widget>
</display>
RE: BOY - XY Graph and macro substitution Chen, Xihui
Prev: RE: Making a case for cases Zhukov, Alexander P.
Next: Re: Making a case for cases Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Theweb site for the EPICS October meeting is now open. http://www.bnl.gov/epics/ Dalesio, Leo
Next: RE: BOY - XY Graph and macro substitution Chen, Xihui
