1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn and I/O intr scanning
To: Hinko Kocevar <[email protected]>
Cc: [email protected]
Date: Tue, 17 Aug 2010 08:44:38 -0700
Have a look at the 'SRQ Processing' section of the devGpib documentation (<asyn>/documentation/devGpib.pdf).  The command table type element should be GPIBREADW (or one of the other GPIBxxxxxxW values) which waits for the device to issue a SRQ then performs the read (or write) operation.
You do not have to use get_ioint_info yourself -- the devGpib code handles this.
On Aug 17, 2010, at 7:44 AM, Hinko Kocevar wrote:
> Hi,
> I've created a device support for simple GPIB according to the
> http://www.aps.anl.gov/epics/modules/soft/asyn/R4-14/HowToDoSerial/tutorial.pdf
> guide. I can get the data from the device as expected.
> Versions: EPICS R3.14.10, Asyn 4-14.
> I've added the SCAN field to my record:
> record(stringin, "$(P)$(R)VOL:N5V")
> 	field(DESC, "Read -5V voltage")
> 	field(DTYP, "RFClock")
> 	field(INP,  "#L$(L) A$(A) @4")
> 	field(SCAN, "I/O Intr")
> At IOC startup I get following message:
> PV: FOO:BAR:VOL:N5V scanAdd: I/O Intr not valid (no get_ioint_info)
> After Googling a bit I found some pointers in 4_3_DeviceSupport_APS.pdf,
> but I'm a bit confused how to actually implement modification in my
> device support.
> If I understand correctly, I need to setup my own DSET with the
> get_ioint_info being defined. Done that:
> static long get_ioint_info (int cmd, struct stringinRecord *si,
> IOSCANPVT *ppvt)
> 	printf("%s:%d ENTER\n", __FUNCTION__, __LINE__);
> 	return 0;
> static gDset DSET_SI_IOSCAN = {
> 	6,
> 	{0, 0, devGpib_initSi, get_ioint_info, devGpib_readSi, 0},
> 	&devSupParms
> epicsExportAddress(dset,DSET_SI_IOSCAN);
> Modified the struct gpibCmd gpibCmds[] = {
> /* Param 4 - Read the -5V voltage */
> /*{&DSET_SI, GPIBREAD, IB_Q_HIGH, "VOL:N5V?", "VOL:N5V %s\r\nOK", 0, 80,
> NULL, 0, 0, NULL, NULL, NULL},*/
> {&DSET_SI_IOSCAN, GPIBREAD, IB_Q_HIGH, "VOL:N5V?", "VOL:N5V %s\r\nOK",
> 0, 80, NULL, 0, 0, NULL, NULL, NULL},
> Now at IOC startup I get following messages:
> FOO:BAR:VOL:N5V : init_record : record type invalid for spec'd GPIB param#4
> Not really sure what needs to done from here on.
> Best regards,
> Hinko
> Hinko Kocevar
> Technical support software engineer
> Instrumentation Technologies d.d.
> Velika pot 22, SI-5250 Solkan - Slovenia
> T:+386 5 3352600, F:+386 5 3352601
> mailto: [email protected]
> http://www.i-tech.si - When your users demand stability
> The information transmitted is intended solely for the addressee and may
> contain confidential and/or privileged information. Any review, retention,
> disclosure or other use by persons other than the intended recipient is
> prohibited. If you received this in error, please notify the sender and
> delete all copies.
Eric Norum
[email protected]
Re: Asyn and I/O intr scanning Hinko Kocevar
Prev: Asyn and I/O intr scanning Hinko Kocevar
Next: Re: Asyn and I/O intr scanning Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Asyn and I/O intr scanning Hinko Kocevar
