1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: msi again
To: [email protected]
Date: Fri, 20 Aug 2010 11:46:50 +0200
After upgrading to msi-1.5, I noticed that definitions in substitution files
are no longer global, but statically scoped (scopes being delimited by curly
braces).
I remember mentioning this on tech-talk as a bug many, many years ago, and
so did others. Every time we got the answer that there are people who rely
on this behaviour, so this could not be changed. So, finally accepting it as
a feature instead of a bug, we also began to rely on it.
And now someone silently fixes it without even bothering to mention it
anywhere, neither on the msi web page, nor in release notes (there are
none), nor can I remember a message on tech-talk (although I haven't checked
the archive to verify this). This is about as bad as it can get.
If compatibility is valued as high as the answers during all those years
suggest, I would have (at least) expected the old behaviour to remain the
default, with the fixed (scoped) behaviour enabled by a command line switch.
Fortunately, I did not delete our old version of msi and could restore it.
Anyway...
We used the old (unscoped) behaviour in order to give global definitions at
the top of the substitution file that should be available to all template
file expansions throughout the substitution file. A typical example goes
like this:
	file /dev/null {{
	    DEVN="KNOGHGP",
	    MCLK="MCLKHGP",
	    PROT="SMG",
	    LINK="$(LINK)",
	    ADDR="$(ADDR)",
	file streamAnalogChan.template
This is something that can no longer be done if definitions are scoped. I
have thought about how to extend the substitution file syntax (and
semantics) of msi so that this can still be done. Here is one possibility:
In addition to
	file <filename> { {<definition-list>} ... }
allow (any number of)
	global { <definition-list> }
blocks at the top-level before any of the the file{}-blocks.
This is very easy to implement and is also completely backwards compatible.
It works the same as if you give additional substitutions on the command
line.
I also propose that we revert to an unscoped semantics for definitions,
introducing a new command line switch to enable the scoped one. This means
people can upgrade to new versions (e.g. to get bug-fixes) w/o having to
change any of their substitution files.
I have implemented and tested all these changes and can provide patches.
Cheers
Ben
PS: One of the patches I sent the last time (the one that allows an instance
for a template file w/o any substitutions) does not work in msi-1.5, it
needs another 3 lines to work.
Prev: Re: Small patch for asynMask bitmask values Angus Gratton
Next: Re: CA gateway dies without error message Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: msi again Andrew Johnson
