1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: streamDevice hex format input
To: "Tian, Yuke" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 13 Sep 2010 16:17:22 +0200
Thanks Yuke, but I have received the same
Could be that I have to configure something on my IOC or somewhere else?
Gorka
De: Tian, Yuke [mailto:[email protected]]
Enviado el: lunes, 13 de septiembre de 2010 16:05
Para: Gorka Ronda; [email protected]
Asunto: RE: streamDevice hex format input
Hi Gorka,
I found if you want to read raw byte, you need to use
in “%4.4r”
as the input format. Please give a try.  The Streamdeive document doesn’t clearly mention this.
-Yuke
From: [email protected] [mailto:[email protected]] On Behalf Of Gorka Ronda
Sent: Monday, September 13, 2010 9:43 AM
To: [email protected]
Subject: streamDevice hex format input
Hi all,
I’m using streamDevice, attempting to communicate with a device sending and receiving in hex format. I achieve to make right the sending, but I have problems with the receiving. I write the following in the protocol file:
cmd1 = \xC0\x01\xFE\x00\x00\x00\x00\x00\x00%<xor>;
c1 {
    out "\$cmd1";
#    in "\xA0\x55\xAA\x5F";
#    in 0xA0 0x55 0xAA 0x5F
#    in "%s";
    in "%*4r";
Like you could see I try different options for input, but any of those and others I try work for me. I like to have an input in hex like, 0xA0 0x55 0xAA 0x5F or A0 55 AA 5F in my soft IOC. Instead, I have the following, which could be ASCII:
epics> 2010/09/13 15:20:08.440 /dev/ttyS0 read 1
\240
2010/09/13 15:20:08.442 /dev/ttyS0 read 3
U\252_
What I have to write exactly for the input?
This is the record I use for that command. What type of record should I use?
record(bi, "$(P)$(R)C1")
    field(DESC, "Comando 1")
    field(DTYP, "stream")
    field(INP,  "@devwbc6600.proto c1 $(PORT) $(A)")
This is the st.cmd file:
cd ${TOP}
dbLoadDatabase "dbd/wbc6600test.dbd"
wbc6600test_registerRecordDeviceDriver pdbbase
# Set up ASYN ports
# drvAsynSerialPortConfigure port ipInfo priority noAutoconnect noProcessEos
drvAsynSerialPortConfigure("L0","$(TTY)",0,0,0)
asynSetOption("L0", -1, "baud", "115200")
asynSetOption("L0", -1, "bits", "8")
asynSetOption("L0", -1, "parity", "none")
asynSetOption("L0", -1, "stop", "1")
asynSetOption("L0", -1, "clocal", "Y")
asynSetOption("L0", -1, "crtscts", "N")
asynOctetSetInputEos("L0", -1, "\n")
asynOctetSetOutputEos("L0", -1, "\n")
asynSetTraceIOMask("L0",-1,0x2) #0x7 para todos los mensajes
asynSetTraceMask("L0",-1,0x9) #0x1f para todos los mensajes
## Load record instances
dbLoadRecords("db/devwbc6600.db","P=$(P),R=$(R),PORT=L0,A=0")
dbLoadRecords("db/asynRecord.db","P=$(P)$(R),R=asyn,PORT=L0,ADDR=-1,OMAX=0,IMAX=0")
## Start EPICS
cd ${TOP}/iocBoot/${IOC}
iocInit
Thanks in advance,
Gorka
RE: streamDevice hex format input Mark Rivers
streamDevice hex format input Gorka Ronda
RE: streamDevice hex format input Tian, Yuke
Prev: RE: streamDevice hex format input Tian, Yuke
Next: RE: streamDevice hex format input Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 13 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
