1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Strange gateway error message
To: EPICS <[email protected]>
Date: Tue, 14 Sep 2010 11:01:30 +0200
Hi all, (Jeff in particular)
Sometime I see in the CA gateway log file entries like this:
filename="../../../../src/cas/generic/casPVI.cc" line number=251
Bad data type application type "enums" string conversion table for
enumerated PV isnt a string type?
Can anyone tell me what this means? Unfortunately it does not print any context like PV name or involved enum strings. So the problem is quite hard to debug.
The message comes from
void casPVI::updateEnumStringTableAsyncCompletion(const gdd & resp)
I suspect this may happen when the enum string set has been modified on the IOC while the channel is connected though the gateway.
Dirk
RE: Strange gateway error message Jeff Hill
Prev: Re: asynchronous record behavior Andrew Wagner
Next: [no subject] Gorka Ronda
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asynchronous record behavior Dirk Zimoch
Next: RE: Strange gateway error message Jeff Hill
ANJ, 16 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
