1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: procServ, not CA Re: [Fwd: RE: Soft IOCs and Port Numbers]
To: EPICS tech-talk <[email protected]>
Date: Fri, 24 Sep 2010 10:32:49 -0400
On 24.09.2010 10:21, Kasemir, Kay wrote:
Hi:
Actually, regarding multiple soft IOCs on the same host at the SNS,
I don't think we have any severe Channel Access issues.
We no longer set the EPICS CA SERVER PORT to a unique number.
You might not think so, but you do:
Any client that does not use UDP broadcasts for name resolution will only see an arbitrary one of the soft IOCs on that server.
Try it: Using EPICS_CA_AUTO_ADDR_LIST=NO (to suppress broadcasts) and EPICS_CA_AUTO_ADDR_LIST=<your server> (to allow directed UDP traffic to your soft IOC server), try any CA client (e.g. caget) to read a variable on one of your soft IOCs. Depending on the number of soft IOCs on your server, you will find a behaviour between connecting every time (only one soft IOC) and almost never (many soft IOCs).
There is a warning message at IOC boot to inform you of that possibly unexpected behaviour.
As long as all your clients use broadcasts, you're fine.
Sorry...
Ralph
Re: procServ, not CA Re: [Fwd: RE: Soft IOCs and Port Numbers] Ralph Lange
Re: procServ, not CA Re: [Fwd: RE: Soft IOCs and Port Numbers] Steven M. Hartman
procServ, not CA Re: [Fwd: RE: Soft IOCs and Port Numbers] Kasemir, Kay
Prev: procServ, not CA Re: [Fwd: RE: Soft IOCs and Port Numbers] Kasemir, Kay
Next: Re: procServ, not CA Re: [Fwd: RE: Soft IOCs and Port Numbers] Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 24 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
